[snappyHexMesh] SnappyHexMesh for setting cellZoneSet/cellSet
Old   March 17, 2020, 20:56
Default SnappyHexMesh for setting cellZoneSet/cellSet
Mitsuru Nishikawa
mit326 is on a distinguished road
Dear all,
Usually, snappyHexMesh is used to extract zone of meshes for calculation area, in which non-calculation area is removed.
Is it possible not to remove the non-calculation area but to set it as cellZoneSet or cellSet?
Kind regards
mit326 is offline   Reply With Quote
Old   March 17, 2020, 21:42
Mitsuru Nishikawa
I could solve this problem by myself.
I used topoSet with setting "source surfaceToCell", then could set cellZone based on STL file.
Thanks a lot.
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 53 November 21, 2019 02:06
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
