[blockMesh] problem generating the mesh
Old   March 26, 2020, 10:47
Default problem generating the mesh
Italy
tony097 is on a distinguished road
Hi everyone, it's the first time here.
I have some problems generating the mesh. below I've attached the geometry of the situation i'm trying to elaborate.
the error message is:
Inconsistent number of faces between block pair 1 and 3
From function void Foam::blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 217.
here is the blockMeshDict.
thank you in advance.
convertToMeters 0.01;
vertices
(-127 0 -7.55)
(-127 5.05 -7.55)
(-127 10.1 -7.55)
(-19 0 -7.55)
(-19 5.05 -7.55)
(-19 10.1 -7.55)
(0 -1.27 -7.55)
(0 0 -7.55)
(0 5.05 -7.55)
(0 10.1 -7.55)
(19 -1.27 -7.55)
(19 0 -7.55)
(19 5.05 -7.55)
(19 10.1 -7.55)
(63.5 -1.27 -7.55)
(63.5 0 -7.55)
(63.5 5.05 -7.55)
(63.5 10.1 -7.55)
(127 -1.27 -7.55)
(127 0 -7.55)
(127 5.05 -7.55)
(127 10.1 -7.55)
(-127 0 7.55)
(-127 5.05 7.55)
(-127 10.1 7.55)
(-19 0 7.55)
(-19 5.05 7.55)
(-19 10.1 7.55)
(0 -1.27 7.55)
(0 0 7.55)
(0 5.05 7.55)
(0 10.1 7.55)
(19 -1.27 7.55)
(19 0 7.55)
(19 5.05 7.55)
(19 10.1 7.55)
(63.5 -1.27 7.55)
(63.5 0 7.55)
(63.5 5.05 7.55)
(63.5 10.1 7.55)
(127 -1.27 7.55)
(127 0 7.55)
(127 5.05 7.55)
(127 10.1 7.55)
blocks
hex (0 3 4 1 22 25 26 23) (15 15 1) simpleGrading (0.5 1.5 1)
hex (1 4 5 2 23 26 27 24) (15 15 1) simpleGrading (0.5 0.5 1)
hex (3 7 8 4 25 29 30 26) (30 15 1) simpleGrading (0.5 1.5 1)
hex (4 8 9 5 26 30 31 27) (30 5 1) simpleGrading (0.5 0.5 1)
hex (6 10 11 7 28 32 33 29) (50 25 1) simpleGrading (2 1 1)
hex (7 11 12 8 29 33 34 30) (50 15 1) simpleGrading (2 1.5 1)
hex (8 12 13 9 30 34 35 31) (50 5 1) simpleGrading (2 0.5 1)
hex (10 14 15 11 32 36 37 33) (30 25 1) simpleGrading (1.5 1 1)
hex (11 15 16 12 33 37 38 34) (30 15 1) simpleGrading (1.5 1.5 1)
hex (12 16 17 13 34 38 39 35) (30 5 1) simpleGrading (1.5 0.5 1)
hex (14 18 19 15 36 40 41 37) (15 25 1) simpleGrading (1.5 1 1)
hex (15 19 20 16 37 41 42 38) (15 15 1) simpleGrading (1.5 1.5 1)
hex (16 20 21 17 38 42 43 39) (15 5 1) simpleGrading (1.5 0.5 1)
edges
boundary
inlet
type patch;
faces
(0 22 23 1)
(1 23 24 2)
outlet
type patch;
faces
(18 40 41 19)
(19 41 42 20)
(20 42 43 21)
upperWall
type wall;
faces
(2 24 27 5)
(5 27 31 9)
(9 31 35 13)
(13 35 39 17)
(17 39 21 43)
lowerWall
type wall;
faces
(0 22 25 3)
(3 25 29 7)
(7 29 28 6)
(6 28 32 10)
(10 32 36 14)
(14 36 40 18)
frontAndBack
type empty;
faces
(0 1 4 3)
(1 2 5 4)
(3 4 8 7)
(4 5 9 8)
(6 7 11 10)
(7 8 12 11)
(8 9 13 12)
(10 11 15 14)
(11 12 16 15)
(12 13 17 16)
(14 15 19 18)
(15 16 20 19)
(16 17 21 20)
(22 23 26 25)
(23 24 27 26)
(25 26 30 29)
(26 27 31 30)
(28 29 33 32)
(29 30 34 33)
(30 31 35 34)
(32 33 37 36)
(33 34 38 37)
(34 35 39 38)
(36 37 41 40)
(37 38 42 41)
(38 39 43 42)
mergePatchPairs
tony097 is offline   Reply With Quote
Old   April 3, 2020, 02:36
Bram Kerkhofs1
brammekeuh987 is on a distinguished road
Hi Tony
Did you found the answer yet?
Your error message is actually quite straight forward:
"Inconsistent number of faces between block pair 1 and 3"
So over here is your answer: Inconsistent number of faces
In the beginning I was also struggling with these kind of problems, the best you can do is google the error message, but without any numbers or names in them. Otherwise it isn't generic enough. So for this you can google " Inconsistent number of faces between block pair and "
Back to the problem: Openfoam start calculating from 0, so the blockpairs which have a problem are:
and
So from a first guess: the grading is in both directions the same, so no issue. But as these blocks 'touch' each other, the number of cells should match for their common face. 15 15 1 and 30 5 1 don't match (at least 2 dimensions should be the same). From the looks of it, the 5 needs to be a 15.
Good luck!
brammekeuh987 is offline   Reply With Quote
[TGrid] Problem when generating volume mesh "tg-is-point-in-region" Tuck ANSYS Meshing & Geometry 1 April 16, 2017 12:19
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
