[snappyHexMesh] Reducing STL size for snappyHexMesh |
February 26, 2023, 11:10 |
Marcus
Rep Power: 3 |
Hi all,
I am currently working on a porous media problem where I am attempting to run pore-scale simulations using an STL model that was produced from X-Ray tomography. Unfortunately, the file size can be large ~15-30gb and makes it difficult to work with. I've tried decimating and smoothing the STL file in Blender and ParaView, however, it almost always results in a bad-quality mesh (the original file produces OK mesh). In my case, bad quality means high aspect ratio cells, zero area face, zero volume cell, non-orthogonal faces and high max skewness. I've linked to a google drive that has a modified STL file (small segment of entire STL), decimated STL with 90% reduction and a template of the snappyHexMeshDict. https://drive.google.com/drive/folde...bI?usp=sharing Does anyone have any tips or recommendation in the best way to reduce the STL size without affecting the mesh produced by SHM. Thanks, Marcus |
February 27, 2023, 03:41 |
Yann
Rep Power: 26 |
Hello Marcus,
I don't know if it can do the trick for you, but SHM can deal with both STL and OBJ file formats, and OBJ format tends to be significantly lighter than STL. (STL only contains triangle faces while OBJ works with polygons) I hope this helps, Yann |
March 6, 2023, 03:45 |
#3 | |
Maries
Rep Power: 16 |
Element quality of surface stl is good, when I see your picture and stl file. Problem is not with decimation, it may be due to very small gaps, spaces etc. You need to find the where these cells are and try to correct the surfaces there. You can also play with snappyhexmesh dict to overcome this. Regards Maries |
blender, decimate, mesh quality, porous media, stl |
An error occurs.'Increase the file catalog size. ' | dhehdxhdaus | CFX | 3 | April 10, 2022 20:13 |
[mesh manipulation] How to split stl file? | sunagra27 | OpenFOAM Meshing & Mesh Conversion | 5 | March 18, 2021 11:00 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
[ICEM] STL file! How is it useful? | bidi | ANSYS Meshing & Geometry | 0 | December 26, 2016 21:33 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
