Dividing blocks as different cell zones
1 Attachment(s)
Hi all,
I have to perform several analyses using Fluent but I preferred by far to develop my mesh using blockMesh. Before implementing the "real" mesh, I had a try exporting a simple 2D domain with a cylinder inside to Fluent, and it was a complete success. Every boundary was correctly defined, everything was ok... BUT I'm facing a problem that I don't know how to solve because I'm quite a newbie with OpenFOAM. My mesh in Fluent needs to have four cell zones (Picture below):
I've been studying the problem and it seems that cell zones have to be defined previously in OpenFOAM before exporting it. I saw a command called "cellZone" but I don't know neither where to implement it nor how to use it. I'd appreciate a lot a bit of help with it. Regards. |
Hi
- The links below may contain some useful info for your learning processes. Hope it helps. |
Thanks a lot for your response, but sadly I wasn't able to solve my problem with any of the links. The good point is that I found some ways that helped me to understand the problem and see different ways to solve it. I attach the links below to help anyone that has this problem. Link 1 (merging meshes): https://www.cfd-online.com/Forums/an...blem-icem.html Link 2 (in the same mesh): https://www.cfd-online.com/Forums/an...ones-icem.html Regards |
