[blockMesh] FOAM FATAL IO ERROR: Block hex is inside-out
Old   May 22, 2020, 00:42
Default FOAM FATAL IO ERROR: Block hex is inside-out
felipe ortega
flowwwww is on a distinguished road
Hello everyone,
I am trying to mesh a very simple shape that involve three different hexes. I set the blockMesh file and run it, but i am dealing with an error message that dont let me obtain my shape.
My blockMeshDict is the following.
convertToMeters 1;
vertices
    (0 0 0)
    (0 3.7 0)
    (1.11 3.7 0)
    (1.11 0 0)
    (0 0 0.54)
    (0 3.7 0.54)
    (1.11 3.7 0.54)
    (1.11 0 0.54)
    (1.11 3.31 0)
    (19.34 3.31 0)
    (19.34 0 0)
    (1.11 3.31 0.54)
    (19.34 3.31 0.54)
    (19.34 0 0.54)
    (19.34 3.7 0)
    (21.74 3.7 0)
    (21.74 0 0)
    (19.34 3.7 0.54)
    (21.74 3.7 0.54)
    (21.74 0 0.54)
blocks
    hex (0 1 2 3 4 5 6 7) (11 37 5) simpleGrading (1 1 1)
    hex (3 8 9 10 7 11 12 13) (182 33 5) simpleGrading (1 1 1)
    hex (10 14 15 16 13 17 18 19) (24 37 5) simpleGrading (1 1 1)
edges
boundary
    box
        type wall;
        faces
            (0 1 2 3)
            (3 8 9 10)
            (10 14 15 16)
            (0 16 4 19)
            (1 2 5 6)
            (8 9 11 12)
            (14 15 18 17)
            (2 6 8 11)
            (14 17 9 12)
    symmetry
        type symmetryPlane;
        faces
            (4 5 18 19)
    doorin
        type patch;
        faces
      (0 1 4 5)
    doorout
        type patch;
        faces
          (15 16 18 19)
mergePatchPairs
The error message is the following.
Create time
Not deleting polyMesh directory
    "/home/felipe/Escritorio/arriba9/constant/polyMesh"
    because it contains blockMeshDict
Creating block mesh from
    "/home/felipe/Escritorio/arriba9/constant/polyMesh/blockMeshDict"
Creating block edges
No non-planar block faces defined
Creating topology blocks
--> FOAM Warning :
    From function Foam::vector Foam::cellModel::centre(const labelList&, const pointField&) const
    in file meshes/meshShapes/cellModel/cellModel.C at line 70
    zero or negative pyramid volume: -0.36963 for face 0
--> FOAM Warning :
    zero or negative pyramid volume: -0.36963 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -0.36963 for face 2
--> FOAM Warning :
    zero or negative pyramid volume: -0.36963 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -0.36963 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -0.36963 for face 5
--> FOAM FATAL IO ERROR:
Block hex (0 1 2 3 4 5 6 7) (11 37 5) simpleGrading (1(1) 1(1) 1(1)) is inside-out
file: /home/felipe/Escritorio/arriba9/constant/polyMesh/blockMeshDict.blocks at line 47.
    From function void Foam::blockDescriptor::check(const Foam::Istream&)
    in file blockDescriptor/blockDescriptor.C at line 83.
FOAM exiting
Best regards!
flowwwww is offline   Reply With Quote
This mesh contains patches of type empty but is not 1D or 2D oric OpenFOAM Running, Solving & CFD 36 November 28, 2016 07:12
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
