June 3, 2020, 01:25 |
How to get rid of defaultFaces
felipe ortega
Rep Power: 6 |
Hello everyone,
I am working in the creation of a domain with blockMesh to simulate a problem. This domain is quite simple, but i have not could reach a good result due to the defaultFaces. The domain that i am trying to obtain is the following. Dominio.png This domain must fit in my geometry. Geometria.png However, when i create the blockMeshDict file and obtain the result that i am looking for, between the boundarys , appears four defaultFaces that are located into the geometry, and when i try to mesh the geometry with snappyHexMEsh, the geometry get cut by the defaultFaces and dont let it be meshed. defautlFaces.png Can i get rid of the defayltFaces or disable them. Code:
convertToMeters 1; vertices ( (0 0.39 0) (0.16 0.39 0) (0.16 3.31 0) (0 3.31 0) (0 0.39 0.54) (0.16 0.39 0.54) (0.16 3.31 0.54) (0 3.31 0.54)//7 (1.11 0.39 0) (1.11 3.31 0) (0.16 0.39 0.3) (1.11 0.39 0.3) (1.11 3.31 0.3) (0.16 3.31 0.3)//13 (1.11 3.7 0) (0.16 3.7 0) (1.11 3.7 0.3) (0.16 3.7 0.3)//17 (1.11 0.39 0.54) (1.11 3.31 0.54)//19 (19.34 0.39 0) (19.34 3.31 0) (19.34 0.39 0.54) (19.34 3.31 0.54)//23 (20.29 0.39 0) (20.29 3.31 0) (19.34 0.39 0.3) (20.29 0.39 0.3) (20.29 3.31 0.3) (19.34 3.31 0.3)//29 (20.29 3.7 0) (19.34 3.7 0) (20.29 3.7 0.3) (19.34 3.7 0.3)//33 (20.29 0.39 0.54) (20.29 3.31 0.54)//35 (21.74 0.39 0) (21.74 3.31 0) (21.74 0.39 0.54) (21.74 3.31 0.54)//39 ); blocks ( hex (0 1 2 3 4 5 6 7) (2 29 5) simpleGrading (1 1 1) hex (1 8 9 2 10 11 12 13) (10 29 3) simpleGrading (1 1 1) hex (2 9 14 15 13 12 16 17) (10 4 3) simpleGrading (1 1 1) hex (10 11 12 13 5 18 19 6) (10 29 2) simpleGrading (1 1 1) hex (8 20 21 9 18 22 23 19) (182 29 5) simpleGrading (1 1 1) hex (20 24 25 21 26 27 28 29) (10 29 3) simpleGrading (1 1 1) hex (21 25 30 31 29 28 32 33) (10 4 3) simpleGrading (1 1 1) hex (26 27 28 29 22 34 35 23) (10 29 2) simpleGrading (1 1 1) hex (24 36 37 25 34 38 39 35) (14 29 5) simpleGrading (1 1 1) ); edges ( ); boundary ( box { type wall; faces ( (0 1 4 5) (1 8 10 11) (10 11 5 18) (8 20 22 18) (20 24 26 27) (26 27 22 34) (24 36 38 34)//floor (0 1 2 3) (1 8 9 2) (2 9 14 15) (8 20 21 9) (20 24 25 21) (21 25 30 31) (24 36 37 25)//back (3 2 7 6) (14 15 16 17) (13 12 6 19) (9 21 23 19) (30 31 32 33) (29 28 23 35) (25 37 35 39)//top (2 15 13 17) (13 12 16 17) (12 16 14 9)//inlet1 (21 31 33 29) (29 28 32 33) (25 30 32 28)//inlet2 ); } symmetry { type symmetryPlane; faces ( (4 5 6 7) (5 18 19 6) (18 22 23 19) (22 34 35 23) (34 38 39 35) ); } doorin { type patch; faces ( (0 3 4 7) ); } doorout { type patch; faces ( (36 37 38 39) ); } ); mergePatchPairs |
[Gmsh] unwanted defaultFaces after exporting to foam 5.0 | deepbandivadekar | OpenFOAM Meshing & Mesh Conversion | 8 | July 3, 2018 16:37 |
[Commercial meshers] How to get rid of internal walls (surfaces)? | bmikuz | OpenFOAM Meshing & Mesh Conversion | 17 | December 5, 2013 15:24 |
How can I get rid of defaultFaces in o folder? | AbbasRahimi | OpenFOAM Pre-Processing | 0 | February 7, 2013 14:03 |
How to get rid of the defaultFaces, Courant number diverge. | liguifan | OpenFOAM Running, Solving & CFD | 1 | April 30, 2011 23:13 |
[Gmsh] How to get rid of the defaultFaces | liguifan | OpenFOAM Meshing & Mesh Conversion | 0 | April 30, 2011 22:53 |
