[Other] Overset axisymmetric meshing
Old   June 11, 2020, 05:37
Default Overset axisymmetric meshing
Mike Worth
MikeWorth is on a distinguished road
I'm trying to construct a model that uses overset meshing in an axisymmetric geometry. The moving mesh region needs to go all the way to the rotational axis, which is causing me problems.
Cutting everything off at the axis (leaving my moving mesh a 'c-shape') doesn't work because then the area within the c isn't totally bounded and therefore isn't picked up as a 'hole'. If I extend the moving mesh past the axis it tries to solve for that region, giving unphysical results that crash the solver.
Has anyone worked out an approach to achieve this before?
Thanks,
Mike
MikeWorth is offline   Reply With Quote
[Commercial meshers] Problems in meshing 2D axisymmetric nozzle wedge with Salome kim4545 OpenFOAM Meshing & Mesh Conversion 1 March 20, 2023 11:05
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 05:03
Overset meshing benji CFD STAR-CCM+ 1 June 28, 2019 08:01
[ANSYS Meshing] Axisymmetric Meshing archer545 ANSYS Meshing & Geometry 0 March 3, 2012 07:36
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
