[mesh manipulation] How to combine intersecting complex meshes?
Old   June 11, 2020, 11:21
Default How to combine intersecting complex meshes?
Brandon
BrandonS is on a distinguished road
HI all,
I created a mesh using snappyHexMesh, I then copied this mesh, rotated and translated it. Using mergeMeshes i then joined these meshes to create an intersecting mesh resembling an X. Both the meshes represent a rock fracture aperture so the surfaces are very undulating. I now want to join these meshes to create one domain, removing the internal walls at the intersection. I have tried using stitch mesh with both partial and perfect flags as well as without a flag but nothing works. Does anyone have any suggestions how to join the meshes together.
Thank you
BrandonS is offline   Reply With Quote
Old   June 25, 2020, 21:30
me3840 is on a distinguished road
You could consider not joining them at all and just using the AMI.
me3840 is offline   Reply With Quote
Mapping (interpolation) between two meshes Ebrahim OpenFOAM Programming & Development 2 June 15, 2020 13:31
Creating two overlapped meshes in the same case mrishi OpenFOAM Pre-Processing 0 October 8, 2019 17:13
[mesh manipulation] Multiple overlapping meshes koala OpenFOAM Meshing & Mesh Conversion 1 February 1, 2017 05:53
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Complex scalar fields JamR OpenFOAM Programming & Development 0 July 15, 2013 11:29
