[blockMesh] blockMesh, mergePatchPairs
Old   November 24, 2020, 11:21
Question blockMesh, mergePatchPairs
nikhil108's Avatar
Nikhil
nikhil108 is on a distinguished road
Hallo foamers,
I have 5 blocks, which have to be joined together and form 1 block. Only the faces exposed to the outside are supposed to be defined as patches. So, I want to merge faces that are in the middle of the domain. I tried to use mergePatchPairs for that, but unable to merge all patches. The following figures explain the problem more in detail. The yellow faces in the figure have to be merged (to internal faces) and blue faces have to defined as patches. blockMesh file is attached below. I used mergePatchPairs to merge faces, but it works for only any one of the blocks. for example, if I merge face from block 1 to face from block 2 then I cant merge the face from block 1 to face from block 3, don't know why it's not working. Is there any way to do this? Please someone shed some light on this.
cheers,
nick.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
//block01
(-15   0.12  0.00)//0
( 15   0.12  0.00)//1
( 15   20.0  0.00)
(-15   20.0  0.00)
(-15   0.12  8.00)//4
( 15   0.12  8.00)//5
( 15   20.0  8.00)
(-15   20.0  8.00)
//block02
(-15  -0.40  0.00)//8
(-1   -0.40  0.00)
(-1    0.12  0.00)
(-15   0.12  0.00)//11
(-15  -0.40  8.00)//12
(-1   -0.40  8.00)
(-1    0.12  8.00)
(-15   0.12  8.00)//15
//block03
(-1   -0.40  0.00)
(5.0  -0.40  0.00)
(5.0   0.12  0.00)
(-1    0.12  0.00)
(-1   -0.40  8.00)
(5.0  -0.40  8.00)
(5.0   0.12  8.00)
(-1    0.12  8.00)
//block04
(5.0  -0.40  0.00)
(15   -0.40  0.00)//25
(15    0.12  0.00)//26
(5.0   0.12  0.00)
(5.0  -0.40  8.00)
(15   -0.40  8.00)//29
(15    0.12  8.00)//30
(5.0   0.12  8.00)
//block05
(-15  -20.0  0.00)
( 15  -20.0  0.00)
( 15  -0.40  0.00)//34
(-15  -0.40  0.00)//35
(-15  -20.0  8.00)
( 15  -20.0  8.00)
( 15  -0.40  8.00)//38
(-15  -0.40  8.00)//39
blocks  //(0 1 3 2 4 5 7 6)
  hex (0 1 2 3 4 5 6 7)         (60 60 20) simpleGrading (1 1 1) //block1
  hex (08 09 10 00 12 13 14 04) (60 60 20) simpleGrading (1 1 1) //block2
  hex (16 17 18 19 20 21 22 23) (60 60 20) simpleGrading (1 1 1) //block3
  hex (24 25 01 27 28 29 05 31) (60 60 20) simpleGrading (1 1 1) //block4
  hex (32 33 25 08 36 37 29 12) (60 60 20) simpleGrading (1 1 1) //block5
edges
boundary
	bt01
		type	empty;
		faces ( (0 1 5 4) );
	bt02
		type	empty;
		faces ( (00 04 14 10) );
	bt03
		type	empty;
		faces ( (19 23 22 18) );
	bt04
		type	empty;
		faces ( (27 31 05 01) );
	up05
		type	empty;
		faces ( (08 12 29 25) );
	up02
		type	empty;
		faces ( (8 9 13 12) );
	up03
		type	empty;
		faces ( (16 17 21 20) );
	up04
		type	empty;
		faces ( (24 25 29 28) );
	rt02
		type	empty;
		faces ( (9 10 14 13) );
	rt03
		type	empty;
		faces ( (17 18 22 21) );
	lt03
		type	empty;
		faces ( (16 20 23 19) );
	lt04
		type	empty;
		faces ( (24 28 31 27) );
mergePatchPairs
(up05 up02)
(up05 up03)
(up05 up04)
(bt01 bt02)
(bt01 bt03)
(bt01 bt04)
//(rt02 lt03)
//(rt03 lt04)
nikhil108 is offline   Reply With Quote
blockmesh, facematching, mergepatchpairs
[blockMesh] mergePatchPairs with blockMesh Ivanet OpenFOAM Meshing & Mesh Conversion 17 May 4, 2021 10:32
[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions pythag0ra5 OpenFOAM Meshing & Mesh Conversion 1 September 19, 2020 14:38
[mesh manipulation] mergePatchPairs after running blockMesh ashishmagar600 OpenFOAM Meshing & Mesh Conversion 2 March 8, 2019 04:15
[blockMesh] Error running blockMesh with mergePatchPairs on OF2.4.0 deepbandivadekar OpenFOAM Meshing & Mesh Conversion 1 November 25, 2017 14:50
[blockMesh] BlockMesh documentation User Guide clearance of mergePatchPairs proposals benru OpenFOAM Meshing & Mesh Conversion 0 June 9, 2008 02:22
