[Salome] salome mesh to openfoam
Old   June 12, 2020, 17:53
Thumbs down salome mesh to openfoam
Andrzej Świtała
pl96andy is on a distinguished road
Hi all
I'm new to CFD. I'm trying to export 2D mesh to openfoam.
As far I create mesh then make groups from geometry (also tryied in reverse order) than i extrude mesh. Folowing to some tutorials i've deleted groups containing volumes and edges.
I've tryied to convert mesh to .unv format using ideasUnvToFoam and I get following error :
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7-1ff648926f77
Exec   : ideasUnvToFoam Mesh_4.unv
Date   : Jun 12 2020
Time   : 18:27:14
Host   : "efd7015ba3d8"
PID    : 242
I/O    : uncollated
Case   : /home/openfoam/run/test2
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Processing tag:164
Starting reading units at line 3.
l:1
units:"  SI: Meter (newton)"
unitType:2
Unit factors:
    Length scale       : 1
    Force scale        : 1
    Temperature scale  : 1
    Temperature offset : 273.15
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 148596 points.
Processing tag:2412
Starting reading cells at line 297215.
First occurrence of element type 22 for cell 1 at line 297216
--> FOAM Warning :
    From function void readCells(Foam::IFstream&, Foam::DynamicList<Foam::cellShape>&, Foam::DynamicList<int>&, Foam::DynamicList<int>&, Foam::DynamicList<Foam::face>&, Foam::DynamicList<int>&, Foam::DynamicList<int>&)
    in file ideasUnvToFoam.C at line 463
    Reading "Mesh_4.unv" at line 297216
    Cell type 22 not supported
--> FOAM FATAL IO ERROR:
Attempt to get back from bad stream
file: IStringStream.sourceFile at line 0.
    From function bool Foam::Istream::getBack(Foam::token&)
    in file db/IOstreams/IOstreams/Istream.C at line 56.
FOAM exiting
So i've tryied to import from Gmsh (by firstly reading mesh from .med and .unv format). I got following error:
wrong token type - expected int32_t, found on line 1 the word '$MeshFormat'
I'm using newest stable version of openfoam, salome and gmsh.
How should i import mesh to openfoam?
Thank you in advance.
Andrzej
pl96andy is offline   Reply With Quote
Old   June 15, 2020, 03:49
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I guess, that the face groups is causing you trouble.
In this bug report the error "Cell type 22 not supported" is discussed. As cell type 22 is apparently a 2D cell type, my guess is that the face groups of your mesh are the culprit.
Try exporting and importing the mesh without any (face) groups. A mesh consisting of only 3D cells should work.
You can further try to:
  • Export your face groups as STLs meshes
  • Construct faceSets using teh STLs as input using topoSet
  • Create patches from the faceSets using createPatch
GerhardHolzinger is offline   Reply With Quote
import, salome mesh
[Salome] how to setFields in openFOAM when you have imported mesh from salome or other package 13msmemusman OpenFOAM Meshing & Mesh Conversion 11 May 18, 2022 07:30
[Salome] Converting Salome wedge mesh to OpenFOAM anon_q OpenFOAM Meshing & Mesh Conversion 4 March 13, 2019 15:13
[Salome] Step to export mesh from SALOME to OpenFoam for 3D MRF geometry aminem OpenFOAM Meshing & Mesh Conversion 0 September 16, 2014 10:18
[Salome] Mesh Salome 7.3.0 to OpenFoam Ahadi OpenFOAM Meshing & Mesh Conversion 5 July 1, 2014 10:11
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 10:24
