[mesh manipulation] How to convert tetrahedral to polyhedral mesh in OpenFOAM
Like Tree1Likes
  • 1 Post By GerhardHolzinger
Old   July 12, 2020, 22:09
Default How to convert tetrahedral to polyhedral mesh in OpenFOAM
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
Hope you are fine and doing well.
I am trying to convert tetrahedral mesh to polyhedral mesh using polyDualMesh utility in OpenFOAM at:
https://openfoamwiki.net/index.php/P...esh_generation
I can work until step 4, but for the steps 5 and 6, there are some options in commands and I do not know how to use it correctly.
Could someone please help me to clear the command in steps 5 and 6.
My mesh now is as below.
Thank you in advance.
ndtrong is offline   Reply With Quote
Old   July 13, 2020, 07:17
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
What are you trying to achieve? Convert a 3D tet-mesh into a 3D polyhedral mesh, or converting a 2D triangular mesh into a 2D polyhedral mesh.
Note, that the page you linked to was last modified in 2011. Things might be a little bit different now. The page you linked to, seems to be specifically about 2D meshes.
For a 3D mesh, I use the following steps:
  • import a tet mesh, e.g. ideasUNVToFoam
  • run polyDualMesh to create a polyhedral mesh
  • run combinePatchFaces to clean up the mesh
See the attached images for each step.
ndtrong likes this.
GerhardHolzinger is offline   Reply With Quote
Old   July 13, 2020, 09:10
Nguyen Duy Trong
Thanks for your comment
I am trying to convert 2D tetra to 2D polyhedral.
I understand that there are some modifications in that link then I do not know how to work correctly with that.
Could you please share with me some hints with setSet and subsetMesh. I really donít understand it well.
Old   July 14, 2020, 03:12
Gerhard Holzinger
For a 2D mesh, I would recommend the following approach:
  • Convert the 2D triangular mesh into a polyhedral mesh *
  • Extrude one cell layer from the front or back patch, discard the initial mesh
* Note: OpenFOAM only deals with 3D meshes, even in 2D cases. In a 2D case, the mesh is one cell in thickness. Thus, a triangular 2D mesh is in reality a prismatic mesh, with cells having a triangular base.
See the attached images for some snapshots of the process.
Old   July 14, 2020, 04:11
Nguyen Duy Trong
Thanks for your guidance,
Yes, I have already converted 2D triangular mesh into polyhedral mesh with step 2+3 as in tutorial and my mesh now has 2 layers as your 1st figure (please see the attachement).
However, I do not know how to extrude one cell layer from the front or back as you said and how to discard the initial mesh
Old   July 16, 2020, 06:35
Nguyen Duy Trong
I can make both front and back are polyhedral cell mesh but I do not know why my internalMesh is strange like this.
Could you please help me to explain it.
Old   July 16, 2020, 16:01
Gerhard Holzinger
See the commented extrudeMeshDict of OpenFOAM, e.g. here https://github.com/OpenFOAM/OpenFOAM...xtrudeMeshDict
This should be rather self-explanatory.
Old   July 16, 2020, 21:20
Nguyen Duy Trong
Thank you so much for your suggestion with your link
The problem has been solved.
Problem converting from Tetrahedral to Polyhedral Mesh iakov1703 ANSYS 4 March 26, 2020 07:11
[CAD formats] Can OpenFOAM convert foam mesh to stl? liying02ts OpenFOAM Meshing & Mesh Conversion 10 December 30, 2018 10:03
how to set periodic boundary conditions Ganesh FLUENT 14 November 26, 2018 11:26
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
[Technical] is possible to do tetrahedral or polyhedral mesh OpenFoam?? Ale_galleria OpenFOAM Meshing & Mesh Conversion 2 January 11, 2011 06:06
