August 10, 2020, 11:08 |
Dynamic mesh with wedge geometry
Lorenzo
Rep Power: 6 |
Dear all,
I am working on a two-phase flow with vaporization inside circular tube. I am currently using the solver interCondensatingEvaporatingFoam, using the k-omega SST turbulence model and the Lee model for what concerns the phase change heat transfer. I've got some problem about the definition of the mesh. I have built a wedge geometry because it's a vertical upflow, where there are ordinary inlet(type patch), outlet(type patch), axis(type empty), top(type wall) and front and back (type wedge). It could be useful to implement a dynamic mesh which refines the cells involving the interphase between liquid and gas like it's done by dynamicRefineFvMesh. I have tried that one, and also the 2D version, but neither one of them works because the non-hexahedral cells of the axis cannot be treated (they have less than 8 vertices). I wonder if anybody has been in my situation, and if you know how to make a dynamic grid cells which is finer close the interface with a wedge geometry. Thank you all in advance Regards, Lorenzo |
June 17, 2021, 22:01 |
XinZhou
Rep Power: 8 |
Hi,Lorenzo,Have you solved this problem? I have the same problem. Could you give me some advice?
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Update of the variables after dynamic mesh motion. | gtg258f | OpenFOAM Programming & Development | 9 | January 18, 2014 10:08 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
