September 3, 2020, 05:32 |
fluentMeshToFoam 2D
Rep Power: 10 |
Hello Foamers,
I created a 2D mesh of simple cylinder with ANSYS Workbench and I tried to OpenFOAM throught he command Code:
fluentMeshToFoam .msh HTML Code:
fluentMeshToFoam -2D 1 .msh Code:
Create time Found unknown block:(4 Embedded blocks in comment or unknown: ( Found end of section in unknown:) Found end of section in unknown:) Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Found end of section in unknown:) Embedded blocks in comment or unknown:( Found end of section in unknown:) Found end of section in unknown:) Embedded blocks in comment or unknown: ( Embedded blocks in comment or unknown:( Dimension of grid: 2 Number of points: 3730 number of faces: 7309 Number of cells: 3579 Found unknown block:(3010 Embedded blocks in comment or unknown: ( Found end of section in unknown:) �Embedded blocks in comment or unknown:`� �Embedded blocks in comment or unknown:\� �Found end of section in unknown:? �Found end of section in unknown:# �Embedded blocks in comment or unknown:{� Found end of section in unknown:~ \`�Embedded blocks in comment or unknown:� Code:
--> FOAM FATAL IO ERROR: Illegal hex digit: ')' file: input at line 0. From function T Foam::ReadHex(Foam::ISstream&) [with T = int] in file db/IOstreams/Sstreams/ReadHex.C at line 57. FOAM exiting Any idea? Best regards |
fluentMeshToFoam - Volume Fields | aylalisa | OpenFOAM Pre-Processing | 7 | May 16, 2017 13:18 |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 04:56 |
[Commercial meshers] Converting an abaqus mesh using matlab scripts and fluentMeshToFoam | MichaelD | OpenFOAM Meshing & Mesh Conversion | 1 | July 2, 2014 06:34 |
[Commercial meshers] fluentMeshToFoam instead of fluent3DMeshToFoam | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | March 29, 2013 07:58 |
[Commercial meshers] Error fluentMeshToFoam | loneboard | OpenFOAM Meshing & Mesh Conversion | 26 | February 6, 2009 10:20 |
