safranyikf |
December 9, 2020 06:17 |
MEshing problem with HELYX-OS
Hi Folks,
I am newbie in OpenFoam 4.1 and HELYX-OS 2.4. After a seriously difficult installation process, finally the software are working.
Now I am trying to create my first simulation by using a simple pipe with an inlet, and outlet and the pipe wall. The geometry is imported from .stl then bounding box and material point were defined, however the mesh was not created. I got the error message:
--> FOAM FATAL IO ERROR:
size 8776 is not equal to the given value of 40000
The log file:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | For copyright notice see file Copyright |
Build : 4.1-11cb6dafc53a
Exec : blockMesh -dict system/blockMeshDict -case /home/feri/CFD/pipe/pipe
Date : Dec 09 2020
Time : 12:02:30
Host : "ubuntu"
PID : 10189
CtrlDict : "/home/feri/CFD/pipe/pipe/system/controlDict"
Case : /home/feri/CFD/pipe/pipe
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/feri/CFD/pipe/pipe/system/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Reading patches section
Creating block mesh topology
Reading physicalType from existing boundary file
Default patch type set to empty
Check topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 6
Number of defined boundary faces : 6
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
Block 0 cell size :
i : 0.002500000037 .. 0.002500000037
j : 0.002499910071 .. 0.002499910071
k : 0.001000000015 .. 0.001000000015
Writing polyMesh
Mesh Information
boundingBox: (-0.02500000037 -0.02499910071 -0.05000000075) (0.02500000037 0.02499910071 0.05000000075)
nPoints: 44541
nCells: 40000
nFaces: 124400
nInternalFaces: 115600
Patches
patch 0 (start: 115600 size: 2000) name: ffminx
patch 1 (start: 117600 size: 2000) name: ffmaxx
patch 2 (start: 119600 size: 2000) name: ffminy
patch 3 (start: 121600 size: 2000) name: ffmaxy
patch 4 (start: 123600 size: 400) name: ffminz
patch 5 (start: 124000 size: 400) name: ffmaxz
End
Exec : decomposePar -force -noFunctionObjects -case /home/feri/CFD/pipe/pipe
Date : Dec 09 2020
Time : 12:02:30
Host : "ubuntu"
PID : 10191
nProcs : 1
Create time
Time = 0
Create mesh for region region0
Calculating distribution of cells
Selecting decompositionMethod hierarchical
Finished decomposition in 0.03 s
Constructing processor meshes
Processor 0
Number of cells = 10000
Number of faces shared with processor 2 = 1000
Number of faces shared with processor 1 = 1000
Number of processor patches = 2
Number of processor faces = 2000
Number of boundary faces = 2200
Processor 1
Number of faces shared with processor 0 = 1000
Number of faces shared with processor 3 = 1000
Processor 2
Processor 3
Number of processor faces = 4000
Max number of processor patches = 2
Max number of faces between processors = 2000
file: /home/feri/CFD/pipe/pipe/constant/cellLevel from line 18 to line 8838.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/feri/foam/foam-extend-4.1/src/foam/lnInclude/Field.C at line 239.
FOAM exiting
Is any idea what can be the problem?
Thanks in advance, Feri
