-   OpenFOAM Meshing & Mesh Conversion (https://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   [blockMesh] Cylinder in Openfoam blockMesh (https://www.cfd-online.com/Forums/openfoam-meshing/233224-cylinder-openfoam-blockmesh.html)
Enternald January 18, 2021 13:29
2 Attachment(s)
Hi All,
I am trying to create an cylinder using blockMesh, I got 3/4 the way through and noticed that it does not line up properly (shown in the image below). Does anyone know why this is the case?
convertToMeters 0.01;
// Dimensions of the cylinder:
cx 5;
cy 5;
cz 1.0;
cylinderThickness 1.0;
r 0.5;
// Calculations for cylinder geometry:
h #calc "$cylinderThickness+$cz";
tph #calc "$cylinderThickness+$cz+$cz";
vx #calc "$cx+$r";
nvx #calc "$cx-$r";
vy #calc "$cy+$r";
nvy #calc "$cy-$r";
// Calculations for arcs:
c1 #calc "$cx + ($r*cos(45.0))"; //cosine in first quadrant
s1 #calc "$cy + ($r*sin(45.0))"; //sine in first quadrant
c2 #calc "$cx + ($r*cos(135.0))"; //cosine in first quadrant
s2 #calc "$cy + ($r*sin(135.0))"; //sine in first quadrant
c3 #calc "$cx + ($r*cos(225.0))"; //cosine in first quadrant
s3 #calc "$cy + ($r*sin(225.0))"; //sine in first quadrant
c4 #calc "$cx + ($r*cos(315.0))"; //cosine in first quadrant
s4 #calc "$cy + ($r*sin(315.0))"; //sine in first quadrant
vertices
//  Vertices for the cylinder :
//  x      y      z
    ($vx    $cy    $cz)
    ($cx    $vy    $cz)
    ($nvx    $cy    $cz)
    ($cx    $nvy    $cz)
    ($vx    $cy    $h)
    ($cx    $vy    $h)
    ($nvx    $cy    $h)
    ($cx    $nvy    $h)
    ($cx    $cy    $cz)
    ($cx    $cy    $h)
// These are all the 'blocks' in our geometry.
blocks
    hex ( 0 1 8 8 4 5 9 9 )      pores      ( 25  25  25 )    simpleGrading (1 1 1)
    hex ( 1 2 8 8 5 6 9 9 )      pores      ( 25  25  25 )    simpleGrading (1 1 1)
    hex ( 2 3 8 8 6 7 9 9 )      pores      ( 25  25  25 )    simpleGrading (1 1 1)
// Edges is a dictionary where we define arcs between vertices.
edges
    arc 0 1 ($c1 $s1 $cz)
    arc 1 2 ($c2 $s2 $cz)
    arc 2 3 ($c3 $s3 $cz)
    arc 4 5 ($c1 $s1 $h)
    arc 5 6 ($c2 $s2 $h)
    arc 6 7 ($c3 $s3 $h)
// Boundaries is where we define our boundary patches.
boundary
  wall
        type wall;
        faces
            (0 8 8 1)
            (1 8 8 2)
            (2 8 8 3)
    atmosphere
        type patch;
        faces
            (5 9 9 4)
            (6 9 9 5)
            (7 9 9 6)
    sides
        type patch;
        faces
            (0 1 5 4)
            (2 6 5 1)
            (3 7 6 2)
mergePatchPairs
Attachment 82172Attachment 82171
Lookid January 19, 2021 03:57
1 Attachment(s)
Your mesh does not load in Paraview for me.
What I can propose is just to make 1/4 of the cylinder and then mirror the mesh twice, it will avoid you the troubles of making 4 blocks.
Here is a blockMesh I found in this forum some time ago:
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  3.0.0                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    object      blockMeshDict;
// CONTROLS
// number of cells
Nx  50;
NRinner  15;
NRouter  15;
// size ratio of cell at the wall to the free-stream one in the near-wall blocks
expRatWall  0.1; // for BL
expRatWall2  0.1; // pipe-axis direction
convertToMeters 0.001;
// all the vertices are in non-dimensional units
// pipe assumed to have length and radius of 1
vertices
    (0.00000e+00 0.00000e+00 0.00000e+00)
        (0.00000e+00 0.00000e+00 8.00000e-01)
        (0.00000e+00 0.00000e+00 1.00000e+00)
        (0.00000e+00 6.10535e-01 6.10532e-01)
        (0.00000e+00 8.00000e-01 0.00000e+00)
        (0.00000e+00 1.00000e+00 0.00000e+00)
        (0.00000e+00 7.07107e-01 7.07107e-01)
        (1 0.00000e+00 0.00000e+00)
        (1 0.00000e+00 8.00000e-01)
        (1 0.00000e+00 1.00000e+00)
        (1 6.10535e-01 6.10532e-01)
        (1 8.00000e-01 0.00000e+00)
        (1 1.00000e+00 0.00000e+00)
        (1 7.07107e-01 7.07107e-01)
blocks
    hex (0 7 11 4 1 8 10 3) ($Nx $NRinner $NRinner) simpleGrading ($expRatWall2 1 1)
    hex (4 11 12 5 3 10 13 6) ($Nx $NRouter $NRinner) simpleGrading ($expRatWall2 $expRatWall 1)
    hex (3 10 13 6 1 8 9 2) ($Nx $NRouter $NRinner) simpleGrading ($expRatWall2 $expRatWall 1)
edges
        BSpline 1 3 (
                //(0.00000e+00 0.00000e+00 8.00000e-01)
                (0.00000e+00 1.12269e-01 7.92025e-01)
                (0.00000e+00 2.22463e-01 7.62587e-01)
                (0.00000e+00 3.26692e-01 7.24996e-01)
                (0.00000e+00 4.21177e-01 6.86516e-01)
                (0.00000e+00 5.02076e-01 6.52300e-01)
                (0.00000e+00 5.66526e-01 6.25913e-01)
        BSpline 3 4 (
                (0.00000e+00 6.10532e-01 6.10535e-01)
                (0.00000e+00 6.25913e-01 5.66526e-01)
                (0.00000e+00 6.52300e-01 5.02076e-01)
                (0.00000e+00 6.86516e-01 4.21177e-01)
                (0.00000e+00 7.24996e-01 3.26692e-01)
                (0.00000e+00 7.62587e-01 2.22463e-01)
                (0.00000e+00 7.92025e-01 1.12269e-01)
                //(0.00000e+00 8.00000e-01 0.00000e+00)
        BSpline 8 10 (
                //(1 0.00000e+00 8.00000e-01)
                (1 1.12269e-01 7.92025e-01)
                (1 2.22463e-01 7.62587e-01)
                (1 3.26692e-01 7.24996e-01)
                (1 4.21177e-01 6.86516e-01)
                (1 5.02076e-01 6.52300e-01)
                (1 5.66526e-01 6.25913e-01)
        BSpline 10 11 (
                (1 6.10532e-01 6.10535e-01)
                (1 6.25913e-01 5.66526e-01)
                (1 6.52300e-01 5.02076e-01)
                (1 6.86516e-01 4.21177e-01)
                (1 7.24996e-01 3.26692e-01)
                (1 7.62587e-01 2.22463e-01)
                (1 7.92025e-01 1.12269e-01)
                //(1 8.00000e-01 0.00000e+00)
        arc 2 6 (0 0.38268343236508978 0.92387953251128674)
        arc 6 5 (0 0.92387953251128674 0.38268343236508978)
        arc 9 13 (1 0.38268343236508978 0.92387953251128674)
        arc 13 12 (1 0.92387953251128674 0.38268343236508978)
boundary
    inlet
        type patch;
        faces
            (1 2 6 3)
            (3 6 5 4)
            (0 1 3 4)
    outlet
        type patch;
        faces
            (11 10 8 7)
            (12 13 10 11)
            (13 9 8 10)
    wall
        type wall;
        faces
            (9 13 6 2)
            (13 12 5 6)
    symmetryVer
        type symmetryPlane;
        faces
            (2 9 8 1)
            (1 8 7 0)
    symmetryHor
        type symmetryPlane;
        faces
            (11 4 0 7)
            (12 5 4 11)
mergePatchPairs
It will generate the mesh 1 which has a radius and length of 1mm. Then you can run the following commands to scale the mesh to give it the dimensions you want, mirror it to obtain full cylinder and place it where you want to give mesh 2.
blockMesh
transformPoints -scale "(55 5.5 5.5)"
sed -i "s/normalVector.*;/normalVector (0 0 1);/g" system/mirrorMeshDict
mirrorMesh -overwrite
sed -i "s/normalVector.*;/normalVector (0 1 0);/g" system/mirrorMeshDict
# if direction of flow is : z+
transformPoints -rollPitchYaw "(0 -90 0)" # z+
#transformPoints -rollPitchYaw "(0 90 0)" # z-
transformPoints -translate "(0 0 -0.0553)"
# renumber to optimise parallel running
renumberMesh -overwrite
Attachment 82185
