[mesh manipulation] octree polyhedral cells - give checkMesh errors |
April 27, 2022, 13:18 |
Giles Richardson
Rep Power: 13 |
I keep getting - "Faces not in upper triangular order" when running checkMesh on my mesh in 'foam' format. The octree mesh is being written into foam format from fortran. I have addressed the face ordering to so that the neighbour cells are in order. But it still doesnt like something about the 4 faces on one side of the transition cells. Running renumberMesh seems to fix the problem, so it must be something else that needs fixing.
https://twitter.com/garcfd/status/15...WnSnTEM00Io9xg |
April 28, 2022, 07:02 |
octree polyhedral - upperTriangularFace
Giles Richardson
Rep Power: 13 |
OK - so the problem with the upperTriangularFace error is actually not anything to do with the faces not being in upper triangular order !!!
I used renumberMesh.exe, to fix the problem, and then looked at the difference between my original faulty mesh and the new renumbered mesh. The problem seems to be that the smaller red face belongs to the smaller cell. If you switch the ownership of the red face to the larger polyhedral cell (and switch the face neighbour too), then the checkMesh works fine. The node ordering of the red face also has to be reversed, to keep the clockwise convention for the new face owner. https://twitter.com/garcfd/status/15...oWtWq1ZKf29xRQ |
April 28, 2022, 07:03 |
Giles Richardson
Rep Power: 13 |
answering my own posts again (as usual on here) LOL
checkmesh, foam, octree, polyhedral, upper triangular |
Display Modes | |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM Running, Solving & CFD | 6 | January 25, 2019 00:11 |
checkMesh Errors after refineMesh | mgdenno | OpenFOAM | 0 | July 30, 2012 21:39 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
