setFields does not work after running snappyHexMesh parallely
Hey everyone,
my work flow is as follows Code:
1. surfaceFeatureExtract after this when I try to view the setField results I was unable to visualize the result. I have been trying to resolve this for a week. recently I tried to run the snappyHexMesh without using parallel (just using 1 processor). Then I tried to visualize the result and I was able to visulaize it.:confused: I tried parallel running using the info got from this link : https://www.openfoam.com/releases/op...+/parallel.php it also did not help openFoam version - v2012 from all this I came to conclusion there is something wrong with the parallel running portion of the work flow. So I tried few of the suggestion from different error posted in the form regarding parallel run. But still I was unable to fix it:confused: CAn some one PLEASE help me :( if you need further information regarding the case set up please feel free to ask Kind regards vava10 |
>decomposePar
>mpirun -np 4 snappyHexMesh -parallel -overwrite >reconstructParMesh –constant this worked for now for this issue |
