How to handle extra domain creation from splitMeshRegions?
Dear All,
I have created a stl mesh using open3D from point cloud. This mesh was split into two domains as a patch and then added back using "surfaceAdd". Now, this mesh is implemented into snappyHexMeshDict. I mesh is running well. But, when I do splitMeshRegion after some topoSet addition, it creates multiple domains, where my cellZoneRegion has only two regions and I need only these two regions. The multiple domains has only one 1 cell in it. How to handle those.? Can it be addressed somehow in ChangeDictionary (Since I am doing chtMultiRegionSimpleFoam). Or the only way is to change the mesh itself? Below is the snippet of splitMeshRegion. Region Cells ------ ----- 0 457997 1 241 2 1 3 1 4 1 Region Zone Name ------ ---- ---- 0 1 gland 1 0 tumor 2 -1 domain2 3 -1 domain3 4 -1 domain4 Any leads will be appreciated. Regards, Sunag R A. |
Any solution?
did you find a solution for this problem? I also get an extra region when I use the command splitMeshRegions -cellZones -overwrite , it says that it is a dummy file but when I want to run the simulation, openfoam asks for the information of the polymesh of this region which I dont want and I dont care! BTW I should say that I use blockMesh and then snappyHexMesh -overwrite so my theory is that this extra region is probably related to the blockMesh region that is created initially which I want to get rid of for my simulation at the end. Can anybody help me with this problem? how should I get rid of this extra region?! Thank you in advance |
try splitMeshRegions -cellZonesOnly. it worked for me.
