[snappyHexMesh] keyword allowFreeStandingZoneFaces is undefined in dictionary |
May 3, 2021, 06:26 |
Maxime Cabrol
Hi everyone, when I try to use snappyHexMesh on my imported STL file it seems to work well :
Overall mesh bounding box : (-1 0 -1) (1 1 1) Relative tolerance : 1e-06 Absolute matching distance : 3e-06 Reading refinement surfaces. Read refinement surfaces in = 0.01 s Reading refinement shells. Refinement level 2 for all cells inside cylinder.stl Read refinement shells in = 0.01 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read edgeMesh cylinder.eMesh points : 880 edges : 880 boundingBox : (-20 -19.9938 -50) (51 19.9938 50) Refinement level according to distance to "cylinder.eMesh" (880 points, 880 edges). level 1 for all cells within 0 metre. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 192500 Number of edges to retest : 192500 Number of intersected edges : 0 Calculated surface intersections in = 1.12 s Initial mesh : cells:62500 faces:192500 points:67626 Cells per refinement level: 0 62500 Adding patches for surface regions ---------------------------------- Patch Type Region ----- ---- ------ cylinder: 4 wall cylinder Added patches in = 0.01 s Selecting decompositionMethod none Code:
FOAM FATAL IO ERROR: keyword allowFreeStandingZoneFaces is undefined in dictionary "/home/maxime/postGeo/system/snappyHexMeshDict.castellatedMeshControls" file: /home/maxime/postGeo/system/snappyHexMeshDict.castellatedMeshControls from line 52 to line 148. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 566. Code:
convertToMeters 1; //This gives you the scale: 0.001 would mean all units in this file are [mm] vertices //list of vertices defining the geometry ( (-1 0 -1) //This is point 0. Not 1! (1 0 -1) //This is point 1 (1 1 -1) //point 2 (-1 1 -1) //point 3 (-1 0 1) //point 4 (1 0 1) //point 5 (1 1 1) //point 6 (-1 1 1) //point 7 /* . .. . . . . . . . . . . . . . . . . . . . . On ajoute une surface au centre du cube servant de "inlet" */ (-1 -1 0.1) // i1 point 8 (-1 -1 0.2) // i2 .. 9 (-1 -0.9 0.2) // i3 .. 10 (-1 -0.9 0.1) // i4 .. 11 /* . . . . . . . . . . . . . . . . . . . . . Sortie du fluide . . . . . . . .. .. . . . . . . . . . . . . */ (1 0 0.99) // s5 point 12 (1 1 0.99) // s6 .. 13 ); blocks //defining the block which the geometry is made out of ( hex (0 1 2 3 4 5 6 7) (50 25 50) simpleGrading (1 1 1) ); boundary ( walls //choose a name for the boundary { type wall; //define the type of the boundary faces ( (0 4 5 1) // face 1 haut (3 7 6 2) // face 2 bas ); } inlet { type patch; faces ( (0 4 7 3) // face 3 gauche ); } outlet { type patch; faces ( (2 1 5 6) // face 4 droite ); } frontAndBack { type wall; faces ( (1 2 3 0) // face 5 avant (7 6 5 4) // face 6 arriθre ); } ); |
freestandingzonefaces, import, snappyhexmesh, stl |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
