[snappyHexMesh] Snappy leaves out one Geometry
Old   April 30, 2021, 05:20
Default Snappy leaves out one Geometry
Claudia
Clau.77 is on a distinguished road
Hey guys!
I am using OF version 8. My aim is to mesh a tray filled with chocolate surrounded by air. I am able to mesh the tray with the air but when I try to at a chocolate bar, snappy doesn't find the cell zone for the chocolate, only the face zone (as you can see in the attached picture).
Here the blockMesh:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
xMin -0.42;
xMax 0.42;
yMin -0.12;
yMax 0.1;
zMin -0.22;
zMax 0.14;
vertices
    ($xMin    $yMin    $zMin)    //0
    ($xMax    $yMin    $zMin)    //1
    ($xMax    $yMax    $zMin)    //2
    ($xMin    $yMax    $zMin)    //3
    ($xMin    $yMin    $zMax)    //4
    ($xMax    $yMin    $zMax)    //5
    ($xMax    $yMax    $zMax)    //6
    ($xMin    $yMax    $zMax)    //7
blocks
    hex (0 1 2 3 4 5 6 7)
    (100 40 45)
    simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
         (0 4 7 3)
    outlet
        type patch;
        faces
            (2 6 5 1)
    walls
        type patch;
        faces
            (3 7 6 2)
            (4 5 6 7)
            (0 3 2 1)
            (0 1 5 4)
mergePatchPairs
and here the snappyHexMeshDict:
|  \\    /   O peration     | Version:  8                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
geometry
   Form.stl
        type triSurfaceMesh;
        name Form;
   Luft.stl //=air
       name Luft;
   Schokolade.stl
       name Schokolade;
castellatedMeshControls
    maxLocalCells 10000000;
    maxGlobalCells 20000000;
    minRefinementCells 0;
    nCellsBetweenLevels 1;
    features
     { file "Form.eMesh"; level 2; }
     {file "Schokolade.eMesh"; level 2; }
     {file "Luft.eMesh"; level 1;}
    refinementSurfaces
        Form
      level ( 2 2 );
            cellZone Form;
            faceZone Form;
            cellZoneInside inside;
        Luft
      level ( 1 1 );
            cellZone Luft;
            faceZone Luft;
        Schokolade
      level ( 2 2 );
            cellZone Schokolade;
            faceZone Schokolade;
    resolveFeatureAngle 40;
    refinementRegions
      Form
            mode inside;
            levels ((1 1));
    locationInMesh (-0.0151 0.031 0.001);
    allowFreeStandingZoneFaces false;
snapControls
  nSmoothPatch 4;
  tolerance 2.0;
    nSolveIter 150;
    nRelaxIter 15;
    nFeatureSnapIter 15;
        implicitFeatureSnap true;
        explicitFeatureSnap false;
        multiRegionFeatureSnap false;
addLayersControls
    relativeSizes false;
    layers
        Form
            nSurfaceLayers 2;
            expansionRatio 1.2;
            finalLayerThickness 0.0004;
            minThickness 0.00007;
    expansionRatio 1.3;
    finalLayerThickness 0.07;
    minThickness 0.0001;
    nGrow 0;
    featureAngle 75;
    nRelaxIter 5;
    nSmoothSurfaceNormals 4;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.8;
    maxThicknessToMedialRatio 0.6;
    //nMedialAxisIter 4;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    //nRelaxedIter 5;
meshQualityControls
    #include "meshQualityDict"
    /*relaxed
        //- Maximum non-orthogonality allowed. Set to 180 to disable.
        maxNonOrtho 180;
    nSmoothScale 4;
    errorReduction 0.75;
writeFlags
    scalarLevels    // write volScalarField with cellLevel for postprocessing
    layerSets       // write cellSets, faceSets of faces in layer
    layerFields     // write volScalarField for layer coverage
mergeTolerance 1E-6;
I am getting three types of warnings:
Introducing baffles to block off problem cells
--> FOAM Warning :
    From function Foam::labelList Foam::meshRefinement::nearestPatch(const labelList&) const
    in file meshRefinement/meshRefinementProblemCells.C at line 440
    Did not visit some faces, e.g. face 0 at (-0.4116 -0.11725 -0.216)
Assigning  these cells to patch 3
markFacesOnProblemCells : marked 0 additional internal faces to be converted into baffles.
Analyzed problem cells in = 1.47 s
--> FOAM Warning : Displacement (-8.2175873e-06 0 7.1834088e-06) at mesh point 64855 coord (-0.31020895 0.028528494 -0.10086257) points through the surrounding patch faces
Smoothing displacement ...
Iteration 0
Iteration 10
Iteration 20
Iteration 30
Iteration 40
Iteration 50
Iteration 60
Iteration 70
Iteration 80
Iteration 90
Iteration 100
Iteration 110
Iteration 120
Iteration 130
Iteration 140
Displacement smoothed in = 12.48 s
--> FOAM Warning :
    From function void Foam::snappySnapDriver::doSnap(const Foam::dictionary&, const Foam::dictionary&, Foam::scalar, Foam::scalar, const Foam::snapParameters&)
    in file snappyHexMeshDriver/snappySnapDriver.C at line 2764
    Did not successfully snap mesh. Continuing to snap to resolve easy
    surfaces but the resulting mesh will not satisfy your quality constraints
so obviously I did something wrong, but I am not that experienced with OF, so I don't know what to do. I tried playing with the resolveFeatureAngle and increased the iterations but it didn't help.
Also I am not sure about the coordinates for the locationInMesh. Right now it is somewhere in the tray (=Form). How do I know what coordinates to choose when I have mulitple geometries?
I hope that someone can give me some advice, i am really stuck here
Clau.77 is offline   Reply With Quote
Old   April 30, 2021, 08:30
Claudia
Update: I managed to create a mesh, the solution was to leave out the regionRefinement (I guess the problem here is that you are suppose to use patches and not the whole geometry?) and setting the tolerance higher.
displacement, meshing, snappyhexmesh, version 8
[mesh manipulation] Full or half geometry to use? vava10 OpenFOAM Meshing & Mesh Conversion 0 March 14, 2021 07:31
[ICEM] Holes in complex ICEM geometry alecbann ANSYS Meshing & Geometry 2 April 4, 2019 03:40
Error while running pisoFoam with snappy but ran smoothly without snappy in empty dm faiazk OpenFOAM Running, Solving & CFD 0 October 24, 2018 13:51
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 13:49
Export geometry file from ansys mechanical browns6 Structural Mechanics 0 August 27, 2013 16:19
