[snappyHexMesh] Boundary layers with snappyHexMesh
Old   May 3, 2021, 08:36
Default Boundary layers with snappyHexMesh
Roman Pavlov
pvlvrmn is on a distinguished road
Hello!
On the screenshot you can see patches 'walls' (violet), 'outlet_cold' (green) and 'side1' (blue).
I'm trying to figure out how to determine correct boundary layers for vortex tube. I need layers for patch 'wall', but only on 'side1'. It's applies also on outlet_cold.
So the question is how to remove additional layers on connection of 'side1' and 'outlet_hot'?
Snappy hex mesh dict: https://www.codepile.net/pile/B8N0ANY3
pvlvrmn is offline   Reply With Quote
Old   May 4, 2021, 04:20
M
AtoHM is on a distinguished road
Normally you can control whether the layers collapse on angled patches or not by adjusting the "featureAngle" in addLayerControls.
Problem here is, this setting will probably either collapse the layers or not on both adjacent faces, as there is a angle of 90 deg at both.
Only possibility I see here is to split the 'walls' patch, make a small stripe at the end in front of 'outlet_cold' where you do not extrude layers on. Then the layers from 'walls' will collapse right in front.
Make sure that stripe is as wide as at least one cell size there, otherwise it might get swallowed during mesing and then the setting is ignored. And use multiRegionFeatureSnap true; if you don't already. I don't open links to external sites here.
AtoHM is offline   Reply With Quote
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
