BlockMesh Error in cylinder case
Hello!!
I'm stuck there while performing cylinder case, please help me. FOAM FATAL ERROR: (openfoam-2012) cannot find file "/home/...../OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/system/system/controlDict" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 547. |
how do you launch the blockMesh tool? And where?
You must be in the cylinder directory. Inside this one, you have the system, constant and 0 directories. And inside the sytem directory, you have the controlDict file Edit : the system/system path is not correct... I think you launched "blockMesh" IN the system directory. Just go in the cylinder directory and type "blockMesh" |
Done as you said but still not working what to do,
Creating block mesh from "system/blockMeshDict" Using #codeStream at line 23 in file "/home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/system/blockMeshDict" Using #codeStream with "/home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so" Could not load "/home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so" /home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so: cannot open shared object file: No such file or directory Creating new library in "dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so" Invoking wmake libso /home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063 wmake libso /home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063 /opt/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 637: make: command not found /opt/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 640: make: command not found wmake error: file 'Make/linux64Gcc63DPInt32Opt/sourceFiles' could not be created in /home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063 --> FOAM FATAL IO ERROR: (openfoam-2012) Failed wmake "dynamicCode/_49e41d753f2adb4c8dffc0259424b06af57db063/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_49e41d753f2adb4c8dffc0259424b06af57d b063.so" file: /home/shiny/OpenFoam/tutorials/tutorials/basic/potentialFoam/cylinder/system/blockMeshDict at line 17 to 21. From static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 197. |
Now it is an other problem. make is not installed...
Check the system requirements : https://www.openfoam.com/documentati...m-requirements (make is in the build-essential package) |
