June 3, 2021, 05:24 |
snappyHexMesh error
Scott
Rep Power: 4 |
Can someone please explain what this error that I am getting when using snappyhexmesh means?
--> FOAM Warning : From function void Foam::snappySnapDriver::calcNearestFace(Foam::label, const indirectPrimitivePatch&, const scalarField&, Foam::vectorField&, Foam::vectorField&, Foam::labelList&, Foam::vectorField&) const in file snappyHexMeshDriver/snappySnapDriverFeature.C at line 397 Did not find surface near face centre (2.0221 2.2348 0.0305235) |
June 3, 2021, 05:34 |
Rep Power: 8 |
Hey LividBark,
to help you, i think you have to post a little bit more information. Best regards Kai |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
