[snappyHexMesh] Is is possible to snap geometries from a mesh that doesn't satisfy 2:1 transition? |
June 6, 2021, 14:27 |
Junting Chen
Rep Power: 10 |
Hello all, this is what I am trying to do:
1. blockMesh 2. snapyHexMesh with only "castellation" on (for later refineMesh purpose) 3. run simpleFoam for n iterations, get some field values 4. topoSet grabbing cells based on one of the field value 5. refineMesh applied to cells grabed from topoSet (i dont think refineMesh works well on cell type other than hex, or i didnt do it right) 6. snappyHexMesh snap geometry edges, maybe add layers too. When running snappyHexMesh in step 6, system tells me: Celllevel does not satisfy 2:1 constraint it is reasonable.. because refineMesh for sure will mess up refinement level transition.. but I also wondering if the requirement of smooth transition is required in the snapping stage. If not, is there a way to bypass it? Thanks in advance, Junting Chen Last edited by chen112p; June 6, 2021 at 14:28. Reason: beautify lines |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 15:33 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
