June 7, 2021, 04:51 |
Using transfinite command in Gmsh
Arijit Saha
Rep Power: 7 |
Hello everyone,
I m getting my hands on with the meshing in gmsh and later use the file in OpenFoam for simulation purpose. I m facing some problems with an easy case. The mesh script file is attached with this thread you can have a look. I used the size field command to capture the wake region around the airfoil but I m also curious to use the command 'transfinite curve' at the leading edge. While I used it I observed no change in the mesh structure. Is it like if the 'size field' command is used then no other mesh sizing command doesn't remain functional? |
[Gmsh] "Perhaps you have not exported the 3D elements?" | j_moulton | OpenFOAM Meshing & Mesh Conversion | 14 | October 6, 2022 21:58 |
gmshToFoam error | erkampasha | Main CFD Forum | 1 | March 22, 2021 13:52 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
GMSH - Very strange effect - Mesh elements deleted when saving | Araist | Mesh Generation & Pre-Processing | 3 | July 15, 2015 06:03 |
[Gmsh] Layers in a curved surface | Artex85 | OpenFOAM Meshing & Mesh Conversion | 1 | December 18, 2011 08:51 |
