[snappyHexMesh] Bad mesh snapping hull aft.area |
June 18, 2021, 14:16 |
Andrea
Rep Power: 9 |
Hi everyone,
I'm facing a bad issue concerning the snapping of the aft.area of the hull I'm meshing (see pics attached). Obviously, if I try to place the boundary layer, SHM can't let it grow in that zone, The STL file has high triangulation refinement in that zone (so I can exclude poor geometry resolution). Any ideas? Please find also my SHM dict attached. I have openfoam2012 Thank you |
July 3, 2021, 09:23 |
Claudio Boezio
Rep Power: 6 |
Hello Andrea, I'm not sure if I understand your problem properly. If your issue is sHM growing viscous layer badly or not at all, I have no suggestion for you, other than trying with a grid where all cells intersecting the hull have the same size. Or try meshing with cfMesh.
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 02:22 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 19:34 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
[ICEM] Bad Quality | **Anny** | ANSYS Meshing & Geometry | 7 | May 28, 2015 05:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
