Naming cellzones before splitting
1 Attachment(s)
I have a multiRegion case with 3 different region (region0, Fluid and region 1) as simplified in the attached image. I'm using snappyhexmesh for snapping a STL geometry. For my mesh study the region 0 and region 1 are randomly switching which is pretty anoying to adapt the boundary condition before each run. I would like to precisely rename the undefined regions in outer cell region and inner one before splitting with splitMeshRegion -cellZones . I tried with locationsInMesh command but it conflicts resulting in new nonsense domains. Thx in advance |
I usually use locationsInMesh to define cellZones in multi region cases. How do you define it and what issues are you having with it? Yann |
This is the righ way
After some try and error, I found that a refinement definition cause problems when using locationsInMesh.
I removed the highlighted part and now its not conflicting. refinementSurfaces { Fluid { level (0 0); faceZone Fluid; cellZone Fluid; cellZoneInside inside; } |
OK I understand. In your code, you are defining a cellZone in refinementSurfaces.
refinementSurfaces Code:
locationsInMesh I guess you cannot use both mechanisms at the same time. You have to choose if you want to define your cellZones in refinementSurfaces or with locationsInMesh. Yann PS: just a clarification for people reading this thread: locationsInMesh is only available in the ESI-OpenCFD branch (openfoam.com). In the foundation branch (openfoam.org) you have to define your cellZones in refinementSurfaces. |
Thanks for the explanation. Helped me a lot!
1 Attachment(s)
Hey Yann,
locationsInMesh is however creating a hole in my Mesh, as you can see in the center of the image for my coarse mesh. This does not occur when defining with refinementSurfaces. Is there a way to fix the hole or to define explicitly the unnamed region with therefinementSurfaces as with locationsInMesh? Thx in advance Attachment 85549 |
I'm not aware of a way to fix it except by playing around with the refinement levels (this is very coarse!) and maybe some snapping parameters.
Maybe someone else will have an idea? Yann |
I managed it to solve the naming of the region by roughly attributing cellzone with toposet for region 1 and 2 naming them solid 1 and 2. Then execute sHM which substract the dupllcated cells in the cellzone and adding them to Fluid. Then there three distinct named region.
