[Technical] overset meshing in openfoam (hard) |
August 5, 2021, 04:24 |
Rep Power: 5 |
Hi,foamers!
I am using overPimpleDyMFoam to simulate valve shut and I found a pretty hard problem. First I replaced cylinder case's mid cylinder with my own blockmesh,the result appeared the same with original case. pic1 And I made it bigger to the up and down wall it's still runs smoothly, pic2 But when I change the background mesh to a lean one pic3 the speed gets extremly huge and blow up pic4 And I shrink the mid cylinder it's goes well. pic5 So maybe there is a problem deep in the xxxxxx.C or xxxxxxx.H or just myself missetting something in the case? |
August 5, 2021, 04:41 |
Rep Power: 5 |
5 pics following below
August 5, 2021, 10:47 |
Rep Power: 5 |
Any answer would be appreciated
August 8, 2021, 07:57 |
Rep Power: 6 |
That would be useful of you can share a picture of your mesh. |
August 8, 2021, 08:55 |
Rep Power: 5 |
Hi Fouch,pic6&7 are meshes that diverged,pic8 runs fine. |
August 8, 2021, 15:45 |
Rep Power: 6 |
Something is not clear to me. If I well understood, you simulate a flow around a hole. So why do you have cells inside the hole ?
August 9, 2021, 02:25 |
Rep Power: 5 |
Hi Fouch,after mergeMesh it's act just like this.You can run case overPimpleDyMFoam for more information.
overset, overset mesh |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 25 | August 14, 2022 13:55 |
How to write OpenFoam data from memory, do not write on hard disk | Tanwk | OpenFOAM Programming & Development | 0 | September 14, 2020 03:50 |
Map of this Meshing (sub-)Forum | wyldckat | OpenFOAM Meshing & Mesh Conversion | 0 | April 27, 2019 09:33 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
How hard is it to learn openFOAM? | YourNameHere | OpenFOAM | 16 | October 9, 2011 16:05 |
