[mesh manipulation] How to extract faceLabels from a patch?
Old   August 31, 2021, 23:39
Default How to extract faceLabels from a patch?
Sunag R A
sunagra27 is on a distinguished road
Dear all,
I want to extract faceLabels from a patch, so I wrote the code as shown below.
But, I get the patch with incomplete faces when visualized, although it shows the exact no of faces present in the patch.
1. I saved the faceLabels in a ".txt" file.
2. I used this facelabel in topoSet as "LabelToFace" and converted to VTK using "foamToVTK" for visualization.
3. What is wrong in the code, so that it shows incomplete patch faces although it shows correct amount of faces and also I believe that the faceLabel alignment is not proper.
4. Code
code
        const fvPatch& mesh = this->patch();
        const fvBoundaryMesh& boundaryMesh = mesh.boundaryMesh();
        for (int patch = 0; patch < 1; patch++)
            const word& patchName = mesh.boundaryMesh()[patch].name();
            Info << patchName << endl;
            const fvPatch& cPatch = mesh.boundaryMesh()[patch];
            std::ofstream file;
            file.open("faceID.txt");
            forAll (cPatch, faceI)
                label faceId = cPatch.start() + faceI;
                //Info << faceId << endl;
                file<< faceId << endl;
                file<< nl << endl;
            file.close();
5. Images
a. Patch I needed: Below is the patch that I needed. This image is taken after snappyHexMesh.
https://drive.google.com/file/d/1KUq...ew?usp=sharing
b. Patch I am obtaining: Below is the patch based on code. We can see it has incomplete faces.
https://drive.google.com/file/d/1Rdi...ew?usp=sharing
Any leads will be appreciated.
Thanks and Regards,
Sunag R A.
sunagra27 is offline   Reply With Quote
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 457 March 27, 2024 00:59
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 6 January 12, 2021 05:55
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
