[snappyHexMesh] addLayers for a multiRegion mesh
Like Tree4Likes
  • 1 Post By julieng
  • 3 Post By aendres
Old   May 12, 2020, 03:30
Default addLayers for a multiRegion mesh
Francesca Mangani
FrancescaMangani is on a distinguished road
Hi everybody,
I would like to understand if it is possible to add layers on a surface which is internal to the mesh.
Infact I'm doing a mesh in order to use chtMultiRegionFoam, splitting it with splitMeshRegions.
Therefore my boundaries are those of the block produced by the blockMesh, but I would like to add layers on the surface of my object, which is cointained in this block.
I would be really grateful to those who can give me any hint!
FrancescaMangani is offline   Reply With Quote
Old   August 5, 2020, 12:49
Sammy Breen
SBreen is on a distinguished road
Greetings,
I have the same problem, did you find a solution?
Thank you very much!
SBreen is offline   Reply With Quote
Old   August 5, 2020, 13:15
Sammy Breen
Nevermind I found the solution.
You can use the region0_to_region1 patches. So for example if you have the regions heater and air you can use heater_to_air as a patch for addLayers.
Old   December 24, 2020, 07:59
julien
julieng is on a distinguished road
I try to mesh the interface between 2 regions with sHM.
I try to do your way. But snappy told me that the interface fluid_to_solid is not defined in the log file.
I tried to mesh only castellation and snap first, do a
splitMeshRegions -cellZones -overwrite
And mesh layers after that with no success.
I see on the forum that one solution is to copy paste each mesh obtained with castellation and snap = true and mesh it again in constant/polymesh with layers = true. Repeat it for each regions.
It is not very attractive, is there a more trivial way to do this?
Best regards
julieng is offline   Reply With Quote
Old   December 24, 2020, 08:20
Sammy Breen
I think you might have used the wrong patch name in your layers definition. I used the name of the patch interface between the fluid and solid region. Try looking up the name in paraview maybe.
Hope i could help you and have nice holidays.
Old   December 27, 2020, 15:58
julien
Thank you for your answer. I am stuck since severals days on this.
Why don't you use the standard refinementSurface ? You don't specify faceZone and faceZone?
HTML Code:
 refinementSurfaces
        solid
            // Surface-wise min and max refinement level
            level (2 2);
             regions
                solid_fluid
                  level (3 3);
            faceZone solid; //insideFaces
            cellZone solid; //insideZone
            cellZoneInside inside;
          fluid
            level (0 0);
            faceZone fluid;//insideFaces
            cellZone fluid; //outsideZone
Why don't you snap the surfaces? Maybe you have only straight lines and 90° corners.
In my case I have a curved interface between solid and fluid regions, so I need to snap. I use the correct patch name fluid_to solid (patch name that it would be created with the splitMeshRegions -cellZones command.
HTML Code:
addLayersControls
    relativeSizes false;
    // Per final patch (so not geometry!) the layer information
    layers
        fluid_to_solid
            nSurfaceLayers 6;
            finalLayerThickness 1.05;
          wall
        nSurfaceLayers 6;
The patch wall is layered but not the interface between solid and fluid.
It seems that the mesh at the interface is not conform. The stl files are generated with Salome and are watertight and conform.
HTML Code:
 refinementSurfaces
        solid
            level (2 2);
             regions
                solid_fluid
                  level (3 3);
          fluid
            level (0 0);
HTML Code:
addLayersControls
    layers
        fluid_to_solid
            nSurfaceLayers 6;
          wall
        nSurfaceLayers 6;
Maybe add layers on a curved interface in not an easy task.
Have a nice Christmas
Julien
Julien
Old   December 27, 2020, 16:10
julien
This is the mesh after addlayers operation
No layers added at the interface...
Old   December 28, 2020, 03:59
julien
I found this post very close of mine.
Trouble with snappy and boundary layers
As in your example it is used a typo like this one to define the location in mesh without faceZone, cellZone, cellZoneInside, features
locationsInMesh
((1.4 0.05 0.05) fluid)
((1.6 0.05 0.05) solid)
The problem is that I have an error when I try this way:
HTML Code:
--> FOAM FATAL IO ERROR:
keyword locationInMesh is undefined in dictionary "C:/PROGRA~1/BLUECF~1/OFUSER~1/run/SNAPPY~1/CHCD7B~1/system/snappyHexMeshDict.castellatedMeshControls"
file: C:/PROGRA~1/BLUECF~1/OFUSER~1/run/SNAPPY~1/CHCD7B~1/system/snappyHexMeshDict.castellatedMeshControls from line 98 to line 271.
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 566.
FOAM exiting
Maybe my version of OpenFoam is out of date to support this typo?
bluecfdcore Openfoam 5.
What do you think?
Julien
Old   December 28, 2020, 04:08
julien
I see that this function is not implemented in the Openfoam fundation versions !!
Multiple meshed components missing
Is there a possibility toadd layers at the interface solid-fluid with the foundation version of Openfoam ?
Old   December 29, 2020, 03:28
Domenico Lahaye
dlahaye is on a distinguished road
Does the extrudeMesh utility helps here?
dlahaye is offline   Reply With Quote
Old   December 29, 2020, 07:51
julien
Thank you for your answer. I am looking for a "standard" procedure being able to mesh every cases I will test. Not only this geometry.
Best regards
Old   December 29, 2020, 08:02
julien
Can anyone tell me what is wrong with my typo of layer section, for calling the interface between fluid and solid in my snappyHexMeshDict file?
Old   December 29, 2020, 15:04
julien
Ok, the solution was to do the operation:
And after that it is possible to create BL at the interface
wht likes this.
Old   February 22, 2021, 14:43
Christian
CFD_Freiberg is on a distinguished road
Hello julieng,
nice to hear you could solve the problem.
Could you sum up the successful workflow?
Because i'm in the same position like you at the beginning and i followed your steps but still can't get layers at the interface area.
Here's my workflow.
1. use sHM with castellatedMesh and snap both "true", addLayers is "false"
2. use "splitMeshRegions -cellZones -overwrite"
3. use sHM with castellatedMesh and snap both "false" and addLayers "true"
but there're still no layers at the interface. I'm using OpenFoam 8.
With kind regards
Christian
CFD_Freiberg is offline   Reply With Quote
Old   May 26, 2021, 14:15
Milton Keynes
Mfebbo is on a distinguished road
I am having same issue and still no success copying files from fluid region to contact/polymesh and setting addlayers to true and the other two to false. I have given the right name of the created interface patch to the addlayercontrols section of snappyhexmesh, but still nothing. Someone could explain the right steps to solve it? Many thanks
Mfebbo is offline   Reply With Quote
Old   September 8, 2021, 07:14
Default Workflow
  #16
Aaron Endres
aendres is on a distinguished road
this is a workflow, which worked for me in OpenFoam 9:
blockMesh
foamDictionary -entry "castellatedMesh" -set "true" system/snappyHexMeshDict
foamDictionary -entry "snap" -set "true" system/snappyHexMeshDict
foamDictionary -entry "addLayers" -set "false" system/snappyHexMeshDict
snappyHexMesh -overwrite
rm -r constant/polyMesh
foamDictionary -entry "castellatedMesh" -set "false" system/snappyHexMeshDict
foamDictionary -entry "snap" -set "false" system/snappyHexMeshDict
foamDictionary -entry "addLayers" -set "true" system/snappyHexMeshDict
echo 'snappyHexMesh: coolant layers'
mv constant/coolant/polyMesh constant
mv constant/polyMesh constant/coolant
echo 'snappyHexMesh: metal layers'
mv constant/metal/polyMesh constant
mv constant/polyMesh constant/metal
The case I used was an altered 'heatedDuct' tutorial case with only two regions: coolant and metal. splitMeshRegions creates the two patches metal_to_coolant and coolant_to_metal, which is why I put the following layer definition in system/snappyHexMeshDict:
addLayersControls
    relativeSizes   true;
    minThickness    1e-10;
    finalLayerThickness 0.67;
    expansionRatio  1.5;
    layers
        metal_to_coolant
            nSurfaceLayers  2;
        coolant_to_metal
            nSurfaceLayers  2;
DaveD!, altinel and wht like this.
aendres is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
