[mesh manipulation] [snappyHexMesh] - How to set Facezone directly in snappyHexMesh? |
September 14, 2021, 05:22 |
Daniel
Rep Power: 5 |
Hi guys!
I recentyl dived into a new problem. I have to analyze the forces on a cubic valve, see both images attached. The Thing is, that the plate is very thin (0,3 mm - one cell lenght in CFD) and i want to calculate forces and momentum of the upper and lower (big) side of the valve and so neglecting all forces that act on the thin sides. Thing is, that i am very confused about cellSets, faceSets, faceZones... I know that you can split the .stl with topoSet somehow, but its not helping me either. Normally it should also be possible in SnappyDict? But what should be added there? Thanks in advance!! |
September 24, 2021, 05:36 |
Daniel
Rep Power: 5 |
Has nobody an idea? How is it possible to set facezones per topoSet out of the .stl?
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
[ICEM] Question about the use of ICEM tcl scripting | lnk | ANSYS Meshing & Geometry | 9 | January 16, 2013 09:24 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
