[snappyHexMesh] first cell height and mesh quality |
October 1, 2021, 13:33 |
Lefteris
Rep Power: 15 |
I'm trying to mesh a hull geometry but I can't seem to be able to create prism layers with first cell height 0.001m. If I increase the first cell height (say to 0.007m) I get some layers. If I turn off all quality controls in the meshQualityDict I get all the layers (and they look ok) but then the checkMesh fails. I am using absolute sizes (relativeSizes false) and firstAndRelativeFinal for the thickness model. I've also attached the checkMesh log file in which I notice the following three lines: Code:
<<Number of duplicate (not baffle) faces found: 32. This might indicate a problem. <<Number of faces with non-consecutive shared points: 32. This might indicate a problem. <<Writing 88 faces with non-standard edge connectivity to set edgeFaces but I really don't know where to start looking in order to rectify anything that is implied as the underlying issue. What am I missing? I would appreciate any help. Thanks! PS Code:
addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes false; // thicknessModel keyword that can take the value of: // firstAndOverall; // firstAndExpansion; // finalAndOverall; // finalAndExpansion; // overallAndExpansion; or // firstAndRelativeFinal thicknessModel firstAndRelativeFinal; firstLayerThickness 0.001; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.5; //$fLayerThickness; // Expansion factor for layer mesh //~ expansionRatio 1.2; // Overall thickness of the cells (size specification depends on the // relativeSizes parameter). // Ignored if using finalLayerThickness or firstLayerThickness. //~ thickness 1.5; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // See relativeSizes parameter. minThickness 1e-4; // Per final patch (so not geometry!) the layer information layers { bowPort { nSurfaceLayers 15; //~ thicknessModel firstAndRelativeFinal; //~ firstLayerThickness 0.001; //~ finalLayerThickness 0.5; //~ thickness 0.2; //~ expansionRatio 1.2; //~ minThickness 0.0; } ... ... ...
Lefteris Last edited by Aeronautics El. K.; October 1, 2021 at 15:46. |
October 10, 2021, 16:23 |
Lefteris
Rep Power: 15 |
ok, seeing that no one apparently has any clues to tackle the original question, I'll ask something (hopefully) easier.
Does anyone know which parameter in the meshQualityDict controls the maximum allowed aspect ratio of the cells?
Lefteris |
Display Modes | |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 06:25 |
first cell height of a mesh | Tensian | Main CFD Forum | 0 | February 20, 2014 13:48 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
