Adding Layers to a curved Geometry
4 Attachment(s)
Hello everyone,
I am trying to simulate a flow through a pourous media. Therefore I have a geometry exported out of CAD and tried to mesh it with SHM. I want to do a 2D simulation so i plan on creating a 2D mesh using extrudeMesh after i create the mesh out of the CAD file. I attached the STL File which I use. I tried adding layer using the light red patches. Therefore Layers are added from both sides. Inside the mesh this worked for three layers, however adding more layers results in problems due to the displacement of the other cells. Has anybody an idea how I can add more layers or how I can mesh the cells to follow the boundary? It is very important to the simulation that the cells "follow" the curved geometry at the left side over the hole diameter. I added a screenshot of the mesh with 3 layers, this is how it should look like but the layers over the complete diameter. I also don't understand why the outside of the mesh has no layers (see also screenshot). Has anybody an idea how i can mesh the curved geometry, so that the cells follow the outer walls? With blockMesh and splines i can create a geometry like that but I need the exact geometry from the CAD files. Thanks in advance guys! |
If somebody has an idea how I can mesh the curve geometry without SHM so that the cells are aligned to the curvature I would also appreciate that. I just have to use this geometry, but I am not fixed to using SHM
Here an example using a runtime-generated sphere https://github.com/OpenFOAM/OpenFOAM.../blockMeshDict I guess You'll probably rather want to use something called "searchableSurface" or "searchableTriSurface" ... though I never use this and the precise name may differ (please someone correct me if wrong) You can find more details at the user manual https://cfd.direct/openfoam/user-guide/v9-blockmesh/ |
Thanks in advance, Daniel |
By the end of the section 5.3.3 Projection of vertices, edges and faces it tells you how to look for further examples inside the tutorials on your own Code:
find $FOAM_TUTORIALS -name blockMeshDict | xargs grep -l project Code:
gedit $(find $FOAM_TUTORIALS -name blockMeshDict | xargs grep -l project) https://github.com/OpenFOAM/OpenFOAM.../blockMeshDict https://github.com/OpenFOAM/OpenFOAM.../blockMeshDict Best luck |
