[blockMesh] Make slices in i,j,k direction in Tecplot |
November 11, 2021, 08:45 |
Shengjie Lu
Rep Power: 5 |
Hi,FOAMers:
I use blockMesh to generate a complete structured mesh to simulate flows in a curved open channel. When I check the result with slices in Tecplot, it can only do slices in x,y,z direction (Cartisian Coordinate), not in i,j,k direction. I want to make slices in streamwise direction, that is, to slice along the centerline. So far, I have found the ijkMesh in src/OpenFOAM/meshes/ijkMesh, but still don't know its usage. I post my grid image and blockMeshDict below. Could anyone help me with this issue? Thanks in advance! Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // scale 1.000; vertices ( (0 0 0) // 0 (0.254 0 0) (0 0.476 0) (0.254 0.476 0) (1.041 1.263 0) (1.517 1.263 0) (1.041 1.517 0) (1.517 1.517 0) (2.304 2.304 0) (2.558 2.304 0) // 9 (0 0 0.057) (0.254 0 0.057) (0 0.476 0.057) (0.254 0.476 0.057) (1.041 1.263 0.057) (1.517 1.263 0.057) (1.041 1.517 0.057) (1.517 1.517 0.057) (2.304 2.304 0.057) (2.558 2.304 0.057) //19 ); edges ( arc 2 6 (0.3049 1.2121 0) // upper arcs arc 3 4 (0.4845 1.0325 0) arc 5 9 (2.2531 1.5679 0) arc 7 8 (2.0735 1.7475 0) arc 12 16 (0.3049 1.2121 0.057) // lower arcs arc 13 14 (0.4845 1.0325 0.057) arc 15 19 (2.2531 1.5679 0.057) arc 17 18 (2.0735 1.7475 0.057) ); blocks ( hex (0 1 3 2 10 11 13 12) (160 80 50) // 1 simpleGrading ( ((0.5 0.5 10.331) (0.5 0.5 0.0968)) 1 4.2562 ) hex (2 3 4 6 12 13 14 16) (160 240 50) // 2 simpleGrading ( ((0.5 0.5 10.331) (0.5 0.5 0.0968)) 1 4.2562 ) hex (6 4 5 7 16 14 15 17) (160 80 50) // 3 simpleGrading ( ((0.5 0.5 10.331) (0.5 0.5 0.0968)) 1 4.2562 ) hex (7 5 9 8 17 15 19 18) (160 240 50) // 4 simpleGrading ( ((0.5 0.5 10.331) (0.5 0.5 0.0968)) 1 4.2562 ) ); boundary ( INLET { type cyclic; neighbourPatch OUTLET; faces ( (0 1 11 10) ); } OUTLET { type cyclic; neighbourPatch INLET; faces ( (8 9 19 18) ); } WALLS { type wall; faces ( (2 0 10 12) // left walls (6 2 12 16) (7 6 16 17) (8 7 17 18) (1 3 13 11) // right walls (3 4 14 13) (4 5 15 14) (5 9 19 15) (0 2 3 1) // bottom walls (2 6 4 3) (4 6 7 5) (5 7 8 9) ); } ATMOSPHERE { type symmetryPlane; faces ( (10 11 13 12) (12 13 14 16) (14 15 17 16) (15 19 18 17) ); } ); |
blockmesh, ijk-direction, slices, tecplot |
Advective BC with specified direction (outlet-velocity) | uckmhnds | OpenFOAM Running, Solving & CFD | 0 | August 19, 2018 20:50 |
Fortran unformatted to tecplot binary | sdharmar | Tecplot | 2 | April 9, 2014 07:19 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
a way to make lots of money quick and easy no lies | Dob | Main CFD Forum | 0 | October 10, 2006 16:45 |
TECPLOT | Victor | Tecplot | 0 | October 12, 2004 06:51 |
