[snappyHexMesh] SnappyHexMesh - decomposePar problem |
April 5, 2023, 13:04 |
Alexandros
Rep Power: 9 |
Dear all,
I am using snappyHexMesh for a multiple regions heat fluid flow and heat transfer problem. I have checked heated duct tutorial and also, chtMultiRegionFoam_snappyMultiRegionHeater, which by the way is not working properly. My setup involves a very small cylinder that is imposed in the flow field through a hole in the cylindrical pipe After the snappyHexMesh execution, the log file seems fine, decomposePar fails to work; the following error is found in the log file. Decomposing mesh fluid --> FOAM FATAL IO ERROR: problem while reading header for object decomposeParDict file: C:/OpenFOAM/20.09/Alex-dev/run/pipeProbeTest/system/fluid/decomposeParDict at line 1. From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 559. FOAM exiting The truth is that I am not sure if I am missing something related to proper decomposition of multiregion problems or there is a problem in the setup. (Case files are attached). Please do not check the quality of the mesh, unless you think that have an impact. (Mesh looks bad for the moment, since the setting used in the heated duct tutorial are used.) I work with OpenFoam 20.09 version, downloaded from cfd support (based on headers, it looks like a dev version actually) and installed in windows (8.1). Thanks for your time, Alex |
April 6, 2023, 04:52 |
Rep Power: 4 |
Hey,
After a quick look, I think you should just delete the decomposeParDict files for all the regions, and replace them by the one in the system folder, or just write another from scratch. The current ones seem unreadable. Maybe someone else can confirm. |
April 6, 2023, 08:57 |
Alexandros
Rep Power: 9 |
Many thanks!
They, indeed, look corrupted! |
April 6, 2023, 15:33 |
Alexandros
Rep Power: 9 |
The decomposition seems ok. But now, after Allrun, in the "boundary" file of a region faces that belong to other regions are included! Thanks you in advance! |
April 9, 2023, 11:51 |
Alexandros
Rep Power: 9 |
Ok.
It seems that updating the boundaries "by hand" it can work. But is there any logic for this one or it can be considered a bug? Could someone please let me know if he/she has faced something similar? Thanks in advance, Alex |
April 9, 2023, 12:10 |
Rep Power: 4 |
I am not sure I understood the issue correctly, so this might be totally useless, but did you use decomposePar -allRegions to decompose your mesh regions by regions? The way you describe it makes me think that the mesh was decomposed as one region. With the -allRegions option, you should have a polymesh folder created for each region, so your case structure would look like constant/fluid/polyMesh and constant/solid/polyMesh.
April 9, 2023, 15:21 |
Alexandros
Rep Power: 9 |
Thank you for the response.
The decomposition is made using -all regions. Apologies for the weak explanation. |
April 25, 2023, 18:22 |
Alexandros
Rep Power: 9 |
A more recent version of the configuration is attached. Now, three regions are formed but a small number of faces (about 2) seem to cause the introduction of wrong boundaries in the regions.
I tried to correct boundaries so that only the expected ones are included in each of the regions. - I also noticed that something similar is found in the allrun file of the chtmultiregionheater tutorial -. However, after editing boundaries decomposePar failed with the following error: Alex@AlexPC /cygdrive/c/OpenFOAM/20.09/Alex-dev/run/working/pipeProbefluidMeshRun $ decomposePar -allRegions /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | OpenFOAM for Windows 20.09 (v1) Built by CFD Support, www.cfdsupport.com (based on Symscape). \*---------------------------------------------------------------------------*/ Build : dev-d26757ee1926 Exec : C:\OpenFOAM\20.09\cygwin64\opt\OpenFOAM\OpenFOAM-dev\platforms\cygwin64mingw-w64DPInt32Opt\bin\decomposePar.exe -allRegions Date : Apr 25 2023 Time : 20:51:03 Host : "ALEXPC" PID : 7184 I/O : uncollated Case : C:/OpenFOAM/20.09/Alex-dev/run/working/pipeProbefluidMeshRun nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh fluid Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 0.077 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 21686 Number of faces shared with processor 1 = 970 Number of processor patches = 1 Number of processor faces = 970 Number of boundary faces = 9220 Processor 1 Number of cells = 21686 Number of faces shared with processor 0 = 970 Number of faces shared with processor 2 = 566 Number of processor patches = 2 Number of processor faces = 1536 Number of boundary faces = 8025 Processor 2 Number of cells = 21686 Number of faces shared with processor 1 = 566 Number of faces shared with processor 3 = 473 Number of processor patches = 2 Number of processor faces = 1039 Number of boundary faces = 8142 Processor 3 Number of cells = 21689 Number of faces shared with processor 2 = 473 Number of processor patches = 1 Number of processor faces = 473 Number of boundary faces = 9293 Number of processor faces = 2009 Max number of cells = 21689 (0.010375% above average 21686.8) Max number of processor patches = 2 (33.3333% above average 1.5) Max number of faces between processors = 1536 (52.9119% above average 1004.5) Time = 0 Processor 0: field transfer Processor 1: field transfer Processor 2: field transfer Processor 3: field transfer Decomposing mesh thinWall Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 0.035 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 10714 Number of faces shared with processor 1 = 284 Number of processor patches = 1 Number of processor faces = 284 Number of boundary faces = 13008 --> FOAM FATAL ERROR: Cell 9478contains face labels out of range: 6(30928 -1 38553 38554 21536 21545) Max face index = 39309 From function Foam:olyMesh:olyMesh(const Foam::IOobject&, Foam:ointField&&, Foam::faceList&&, Foam::cellList&&, bool) in file meshes/polyMesh/polyMesh.C at line 659. FOAM aborting This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. Alex@AlexPC /cygdrive/c/OpenFOAM/20.09/Alex-dev/run/working/pipeProbefluidMeshRun When I tried a non-parallel run, the solver performed a single iteration for the fluid and thenit also stopped and the following error message was displayed: Alex@AlexPC /cygdrive/c/OpenFOAM/20.09/Alex-dev/run/working/pipeProbefluidMeshRun $ chtMultiRegionFoam /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | OpenFOAM for Windows 20.09 (v1) Built by CFD Support, www.cfdsupport.com (based on Symscape). \*---------------------------------------------------------------------------*/ Build : dev-d26757ee1926 Exec : C:\OpenFOAM\20.09\cygwin64\opt\OpenFOAM\OpenFOAM-dev\platforms\cygwin64mingw-w64DPInt32Opt\bin\chtMultiRegionFoam.exe Date : Apr 25 2023 Time : 20:51:36 Host : "ALEXPC" PID : 5900 I/O : uncollated Case : C:/OpenFOAM/20.09/Alex-dev/run/working/pipeProbefluidMeshRun nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region fluid for time = 0 Create solid mesh for region thinWall for time = 0 Create solid mesh for region probe for time = 0 *** Reading fluid mesh thermophysical properties for region fluid Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulenceFluid Selecting turbulence model type laminar Selecting laminar stress model Stokes Adding to reactionFluid Combustion model not active: combustionProperties not found Selecting combustion model none Adding to radiationFluid Radiation model not active: radiationProperties not found Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding to fieldsFluid Adding MRF No MRF models present Adding fvOptions *** Reading solid mesh thermophysical properties for region thinWall Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Radiation model not active: radiationProperties not found Selecting radiationModel none Adding fvOptions *** Reading solid mesh thermophysical properties for region probe Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Radiation model not active: radiationProperties not found Selecting radiationModel none Adding fvOptions PIMPLE: Region fluid PIMPLE: No convergence criteria found PIMPLE: Region thinWall PIMPLE: No convergence criteria found PIMPLE: Region probe PIMPLE: No convergence criteria found PIMPLE: Operating solver in transient mode with 1 outer corrector PIMPLE: Operating solver in PISO mode Region: fluid Courant Number mean: 0.00123054 max: 0.0106757 Region: thinWall Diffusion Number mean: 0.836404 max: 317.404 Region: probe Diffusion Number mean: 0.811525 max: 137.86 --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 871 Caught FatalError --> FOAM FATAL ERROR: request for objectRegistry solid from objectRegistry pipeProbefluidMeshRun failed available objects of type objectRegistry are 3 ( probe fluid thinWall ) From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&) const [with Type = Foam:bjectRegistry] in file db/objectRegistry/objectRegistryTemplates.C at line 211. deltaT = 3.1505e-05 --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 871 Caught FatalError --> FOAM FATAL ERROR: request for objectRegistry solid from objectRegistry pipeProbefluidMeshRun failed available objects of type objectRegistry are 3 ( probe fluid thinWall ) From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&) const [with Type = Foam:bjectRegistry] in file db/objectRegistry/objectRegistryTemplates.C at line 211. Region: fluid Courant Number mean: 3.87681e-05 max: 0.000336337 Region: thinWall Diffusion Number mean: 0.0263509 max: 9.99983 Region: probe Diffusion Number mean: 0.0255671 max: 4.34329 deltaT = 3.1505e-05 Time = 3.1505e-05 Solving for fluid region fluid diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 7.95669e-12, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 4.21493e-12, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 2.08602e-12, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 1.21618e-14, No Iterations 1 Min/max T:300 499.841 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 8.55613e-08, No Iterations 18 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.14867e-14, global = -3.53477e-15, cumulative = -3.53477e-15 Solving for solid region thinWall Alex@AlexPC /cygdrive/c/OpenFOAM/20.09/Alex-dev/run/working/pipeProbefluidMeshRun The truth is that I am getting desperate. I just adjusted snappy so that wrong faces are not present. However, still there are wrong boundaries assigned to polymesh/boundary files of my regions. Perhaps, I should finally try explicit featuring now. I cannot think anythink else. Has anyone something else to propose? Clean files can be downloaded from https://drive.google.com/file/d/1RnU...usp=share_link |
April 26, 2023, 04:27 |
#9 |
Rep Power: 4 |
Hey!
I remember struggling with sHM and region definition too. I think the main difference I had with your sHM dictionary is that I used locationsInMesh rather than using cellZoneInside and cellZone for the refinement surfaces. Did you tried that too? EDIT: Yep, what I did was: Code:
refinementSurfaces { domain { level (0 0); regions { fluid_to_solid1 {level (1 2);} fluid_to_solid2 {level (0 1);} walls {level (0 1); patchInfo {type wall;}} } faceZones (fluid_to_solid1 fluid_to_solid2 ); //cellZoneInside inside; //insidePoint (0 0 1.5); facetype baffles; } } locationsInMesh ( ((0 0 0) fluid) ((0 0 0.155000) solid1) ((0 0 0.107000) solid2) ); |
April 26, 2023, 06:09 |
#10 | |
Yann
Rep Power: 25 |
Since AlexandrosVouros is using the foundation branch (openfoam.org) this won't be an option for him. Regards, Yann |
April 26, 2023, 08:18 |
#11 |
Alexandros
Rep Power: 9 |
The truth is that I haven't try locationInMesh so far. However, I might need to change openfoam version for this one.
Thank you both! |
April 26, 2023, 10:05 |
#12 |
Alexandros
Rep Power: 9 |
Dear Alczem,
Could you please verify? 1. locationsInMesh will be used for replacing the existing line for "locationInMesh". The latter will be deleted from snappy 2. The whole domain will be included in a single .stl file, correct? Please note that I have three interfaces, namely: fluid ToProbe, FluidToThinWall and probeToThinWall. Will the faceZones line change accordingly, i.e. faceZones (fluidToProbe fluidToThinWall probeToThinWall ); faceType baffles; Last but not least, in which OF version have you run those cases? I am still working with windows 8.1 (, I know it's a very old machine, indeed) so that I cannot install the latest ESI OF version. Thanks in advance |
April 26, 2023, 11:51 |
#13 | |
Rep Power: 4 |
1. Yep you should only use one and comment out the other 2. Yep again, it should result in one big mesh with cellzones and facezones. Having more than two interfaces should not change anything if they are properly defined I ran this case more than a year ago, so probably OF v2012 or 2106 I would say? Windows 8 is not compatible with the precompiled binaries? That's a shame :/ maybe through a virtual machine and linux? If it is not working, I can only recommend to check the stl files and make sure they are correct (and ideally watertight although sHM will work if it isnt). Keep us posted! |
May 10, 2023, 08:00 |
#14 |
Alexandros
Rep Power: 9 |
Hey!
I finally managed to ensure a watertight outlining (only!) geometry! Baffles are given in separate files. Multi domain regions are there and baffles work as expected. A large number of cells and correct meshing -using the same grid parameters for all the exported stl surfaces -was necessary for salome. The outline surface was checked via surfaceCheck. Working with implicit sHM, there are still some cells that refer to the wrong mesh region. And also, the name of the boundary is included in the polymesh/boundary folders of both regions... Questions: 1) I wonder if I could avoid them by changing parameters. 2) Will layers addition solve this problem? 3) Will explicit sHM provide better results or an even more detailed meshing needs to be developed is salome? 4) 'locationInMesh' is necessary although I think that 'locationsInMesh' could work also (it seems minor now) 5) Finally does allowFreeStandingZoneFaces true/false play a role in this problem? I cannot truly understand what it does. If activated, could I have all the faces baffles included -in a single stl file or is this totally wrong? The link with one (definitely not the best) solution can be found here https://drive.google.com/file/d/1ho4...usp=share_link It has no layers and it can be definitely improved. Many thanks guys! |
May 11, 2023, 04:39 |
#15 | |||||||
Rep Power: 4 |
Hello!
In your boundary files, do you mean that the exact same name appears twice? Or is it something like fluid_to_solid and solid_to_fluid? Usually, the creation of baffles results in a master patch in one region and a slave patch in the other region. So to answer in order ^^ Quote:
Can you post a picture of the problematic cells? It might help to identify the issue EDIT: Sorry, didnt see the case. After a quick look, I think you might have better results by increasing the tolerance to 1.5 or even 2 in the snapping controls. Your boundaries are properly defined IMO. The mesh looks ok (even though you would need more cells in your thin wall region). |
May 12, 2023, 05:53 |
#16 |
Alexandros
Rep Power: 9 |
Many thanks fro the reply!
I modified several things but I am never satisfied (Perhaps, this is rather psychological than practical...) Feature angle was reduced to 1-3, (I would need to apply 180 to featureextract too I think -I need to check) in order to be able to capture the probe_to_fluid_interface. It was very bad actually in the first place so that I increased very much the surface cells from salome and it looks better now. However, there are still two(!) cells under fluid/Patch/probeWall and many more under probe/partch/fluidWall. An image is provided at the end of the message. In fact, those cells lie on the intersection (or better on the feature edge of the probe. I just found the 'delete small regions' in the v2012 version. Hope it will help. (Forgot to mention, I am working now in a new ubuntu 22.04.2 LTS OS and 2212 foam version). Now the most important! You are right about splitting walls with sharp corners. But could you please check the probe_to_fluid interface? I is in fact a cylinder without its top surface. Could I split the baffle somehow? In all the tutorials I have seen, the baffle is given in a single stl file! Finally, could you please elaborate on the "floating" settings. In my case, I have checked in salome that there is a common node (I used merge nodes in salome to this end) for the geom outline and the probe_to_fluid baffle. However, as you definitely know, do not maintain when snappying, otherwise I wouldn't have these problems. Thanks again for the reply. I hope I will come back soon with better results. Last edited by AlexandrosVouros; May 12, 2023 at 06:04. Reason: picture added |
May 12, 2023, 06:06 |
#17 |
Alexandros
Rep Power: 9 |
The image with the problematic cells.
Wondering also if there is a way to define an edge instead of a surface interface in foam. |
May 13, 2023, 05:09 |
#18 |
Alexandros
Rep Power: 9 |
Hi!
A decent solution was achieved with explicit snappying. minCellFraction was succesfully applied! The case can be found under the link below https://drive.google.com/file/d/1Gzb...usp=share_link Additional work needs to be done in the intersection. I think that it is rather mandatory to split the baffle in two surfaces so that the teeth are healed rather than trying to fix errors with snappying parameters. |
May 18, 2023, 03:39 |
#19 |
Alexandros
Rep Power: 9 |
I finally did managed to have a nice -although still with some problematic cells solution. However, since, I think that the topic does not correspond to the real problem I will open a new thread and put the link here.
Thanks again for your help. |
Display Modes | |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] Problem using refineMesh, topoSet and snappyHexMesh | Rasmusiwersen | OpenFOAM Meshing & Mesh Conversion | 0 | October 3, 2019 05:33 |
[snappyHexMesh] Problem with skewd faces in SnappyHexMesh | Friendly | OpenFOAM Meshing & Mesh Conversion | 1 | June 19, 2019 08:05 |
[snappyHexMesh] snappyHexMesh problem with eMesh file | Ingöö | OpenFOAM Meshing & Mesh Conversion | 13 | March 24, 2019 14:46 |
Problem with decomposePar (and mapFields) for large problem | quarkz | OpenFOAM Pre-Processing | 2 | February 21, 2019 10:51 |
