[snappyHexMesh] Using pentagonal cells for refinement |
April 14, 2022, 04:51 |
Pere
Rep Power: 4 |
Dear all,
I have been trying to refine my (2D) mesh in a certain region, let's say with a refinement level of 1. I have done so in two different ways: using blockMesh and then mergePatchPairs, and through snappyHexMesh. Both methods yield similar results: the "transition zones" between the different regions of the mesh use tetra elements (see first figure). In spannyHexMesh, I know you can control the "smoothness" of this transition with the nCellsBetweenLevels entry. So far so good... My doubt comes from having seen meshes where no transition zone exists at all by using snappyHexMesh (see the second figure, taken from the wiki). Note that this is neither a non-conformal mesh nor a "hanging node" situation. It's just that some of the cells are now pentagons instead of squares (if you allow me to use the 2D jargon) and thus can have 5 neighbours instead of 4. Now, my question can be summarized into the following:
Thank you very much! |
April 14, 2022, 09:36 |
Yann
Rep Power: 26 |
Hi Pere,
This is a matter of visualization in ParaView. When loading your case in ParaView, untick the "Decompose polyhedra" option and you should get the same visualization as in the wiki. Cheers, Yann |
April 15, 2022, 05:27 |
Pere
Rep Power: 4 |
Hi Yann,
Thank you very much for the rapid response! I would have never guessed it was a visualization thing. I did not know that some ParaView filters are not good at handling polyhedra and that's why it decomposes them into tetra and pyramids. Good to know! |
mesh, pentagon, refinement |
problem with parallel calculations OF8 mpirun | otaolafr | OpenFOAM Programming & Development | 0 | January 5, 2021 07:33 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
