Salome Meca 2021_LGPL Failing to mesh
1 Attachment(s)
I am trying to expand upon a simulation that I completed a few months ago....(https://www.cfd-online.com/Forums/op...1m-length.html.)
This time I am trying to add my air ducting. The ducting will have a face designated for two fan inlets, outlet location, and an internal object which will impinge on the air flow. Eventually this will be a conjugate heat transfer model, but for now I just want to show how air moves in the system. I began by making two steps files. One for the solid object (red in image) and a volute for the the air (blue in image). The volute representing the air was created in onshape CAD with a boolean operation then saved and imported into Salome Meca 2021 as a STEP file. I have tried previously successful mesh setups on these objects but can not seem to get a good mesh. It either hangs on 0%, fails with surface feature errors, or takes far too long to finish meshing (ends without success). What checks could I do to see if my troubles are geometry based vs mesh parameter based? |
update
1 Attachment(s)
Here is an example of my woes......
getting further
4 Attachment(s)
Okay, so the CAD I imported was apparently throwing off the mesh. I cleaned up the import steps and everything meshed great now. I have attached photos of the isolated mesh views.
The new problem is when I try to run ideasUnvToFoam. I get the error.... Constructing mesh with non-default patches of size: inlet 167 outlet 350 --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&, Foam::pointField&&, const cellShapeList&, const faceListList&, const wordList&, const wordList&, const Foam::word&, const Foam::word&, const wordList&, bool) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595 Found 87387 undefined faces in mesh; adding to default patch. Adding cell and face zones Cell Zone fluid 308045 Face Zone walls 58983 ideasUnvToFoam: ideasUnvToFoam.C:1287: int main(int, char**): Assertion `nouveau > -1' failed. Aborted (core dumped) |
