[Commercial meshers] Small determinant cells on border
Old   April 15, 2022, 07:46
Default Small determinant cells on border
rocco attili
rockonthefloor is on a distinguished road
Hello guys,
I am creating a hexa mesh on a commercial sw (BetaCAE ANSA) and applied OF strict quality criteria. However when i perform checkMesh -allGeometry a number of small determinant cells are found. I had a look on other threads but I did not find a similar case.
When isolating the mentioned cells they appear to be at the border of the domain in the intersection between two faces. Their shape is perfectly tetrahedral. Attached you'll find a series of images to visualize the cells.
These cells are connecting faces with different BCs (patch, symmetry...).
How does checkMesh algorithm calculate the cells determinant? Is the fact that these cells have two faces on the domain border that cause a small determinant? Finally, can I proceed with the simulation with this kind of error, or it is essential to fix it?
Thank you in advance!
Rocco
rockonthefloor is offline   Reply With Quote
Old   April 19, 2022, 06:33
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Rocco,
Indeed this is related to the cells having faces on different domain boundaries. We also have these for many of the cases we run and it is not an issue.
Best Regards,
Tom
tomf is offline   Reply With Quote
Old   April 19, 2022, 06:38
rocco attili
Originally Posted by tomf View Post
Hi Rocco,
Best Regards,
Tom
Hi Tom,
Thank you for the reply!
So, in case of divergence of the solution I can exclude that the cause is related to these warnings? I am triyng to "unbox" the problems to find out the critical issue.
Bests,
Rocco
Old   April 19, 2022, 07:29
Tom Fahner
Hi Rocco,
Well in our cases it was never a problem. Not sure if there are occasions where it would be an issue, but it does not seem likely.
Cheers,
Tom
Old   April 19, 2022, 07:34
rocco attili
Hi Rocco,
Cheers,
Tom
Thank you again.
Rocco
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
