[snappyHexMesh] Demage the background mesh
Old   August 24, 2022, 18:15
Default Demage the background mesh
Christian Pinzón
davcrisp is on a distinguished road
Hi everyone
I'm trying to mesh a a jet in cross flow.
First I have created the main domain in blockMesh with 4 blocks, three block for the main channel, an one for the incline channel, (figure 1).
Second I used snappyHexMesh to mesh a step (figure2) in upstream direction.
When sHM finish the domain near to the intersection area is deforme as is showed figure3.
Could you give me an advise how to do that sHM only meshing the step and not affect the downstream channel intersection? and not affect areas that are not specify in SHM file?? Thanks
SnappyHexMesh Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap            on;
addLayers       off;
geometry
       step_triangle
        type triSurfaceMesh;
        file "step_triangle.stl";
        name step;
castellatedMeshControls
    maxLocalCells           3000000;
    maxGlobalCells          3000000;
    minRefinementCells      10;// Motorbike 10
    maxLoadUnbalance        0.10; //
    nCellsBetweenLevels     2; // buffer cells.
    resolveFeatureAngle     10;// 60?
    gapLevelIncrement       1;
 features
        {file "step_triangle.eMesh"; levels ((0.025 0));}
    refinementSurfaces // Surface-wise min and max refinement level
    step {level (1 1); patchInfo {type wall;};gapLevelIncrement 2;} //(3 3)
   refinementRegions
    locationInMesh (1e-5 1e-5 1e-5); // Offset from (0 0 0) to avoid
    //nCellsBetweenLevels 3;
    allowFreeStandingZoneFaces false;
snapControls
    implicitFeatureSnap         false;
    explicitFeatureSnap         true;
    nSmoothPatch                2;
    nSmoothInternal             $nSmoothPatch;
    tolerance                   2.0;
    nSolveIter                  90;
    nRelaxIter                  15;
    // Feature snapping
    //- Number of feature edge snapping iterations.
    //  Leave out altogether to disable.
    nFeatureSnapIter            10;
    detectBaffles               true;
    multiRegionFeatureSnap      false;
BlockMesh code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
backgroundMesh
 //block_1
    x_b1_Min    -0.198;
    x_b1_Max    -0.006538;           // xMax     0.595;
    y_b1_Min     0;                 //-0.120;
    y_b1_Max     0.120;
    z_b1_Min    -0.0150;
    z_b1_Max     0.0150;
//block_2
    x_b2_Min    -0.006538;
    x_b2_Max     0.006538;       // xMax     0.595;
    y_b2_Min     0;		//-0.120;
    y_b2_Max     0.120;
    z_b2_Min    -0.015;
    z_b2_Max     0.015;
//block_3
    x_b3_Min    0.006538;
    x_b3_Max     0.3;       // xMax     0.595;
    y_b3_Min     0;		//-0.120;
    y_b3_Max     0.120;
    z_b3_Min    -0.015;
    z_b3_Max     0.015;
    zMaxP    0.015;
    xCells 334;  //xCells  240;
    yCells  80; //80;//70
    zCells  16;//13*/
    x_1 80;
    y_1 75;
    x_2 40;
    y_2 75;
    x_3 120;
    y_3 75;
    z_0 44;
    z_1 22;
vertices
//vertices canal principal
    ($:backgroundMesh.x_b1_Min $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b1_Max $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b1_Max $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b1_Min $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b1_Min $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b1_Max $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b1_Max $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b1_Min $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b2_Max $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b3_Max $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b3_Max $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b2_Max $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Min)
    ($:backgroundMesh.x_b2_Max $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b3_Max $:backgroundMesh.y_b1_Min $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b3_Max $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Max)
    ($:backgroundMesh.x_b2_Max $:backgroundMesh.y_b1_Max $:backgroundMesh.z_b1_Max)
 //vertices canal secundario
    (-0.161594 -0.108572 -0.0075)
    (-0.157292 -0.114715 -0.0075)
    (0.006538 0 -0.0075)
    (-0.006538 0 -0.0075)
    (-0.161594 -0.108572 0.0075)
    (-0.157292 -0.114715 0.0075)
    (0.006538 0 0.0075)
    (-0.006538 0 0.0075)
blocks
    hex (0 1 2 3 4 5 6 7)
     $:backgroundMesh.x_1
     $:backgroundMesh.y_1
     $:backgroundMesh.z_0
     simpleGrading (
	    	(1 1 0.07)
            	(0.05 0.30 1)
            	(0.95 0.70 19)
            	1
    hex (1 8 11 2 5 12 15 6)
     $:backgroundMesh.x_2
     $:backgroundMesh.y_2
      simpleGrading (
	    	1
            	(0.05 0.30 1)
            	(0.95 0.70 19)
            	1
    hex (8 9 10 11 12 13 14 15)
    $:backgroundMesh.x_3
    $:backgroundMesh.y_3
     simpleGrading (
	    	(1 1 12)
            	(0.05 0.30 1)
            	(0.95 0.70 19)
            	1
    hex (16 17 18 19 20 21 22 23)
    70
    $:backgroundMesh.z_1)   simpleGrading (1 0.08 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 4 7 3)
    outlet{
        type patch;
        faces
            //(17 18 22 21)
            (9 10 14 13)
    front
        type patch;
        faces
            (4 5 6 7)
            (5 12 15 6)
            (12 13 14 15)
            //(20 21 22 23)
    back
        type patch;
        faces
            (0 3 2 1)
            (1 2 11 8)
            (8 11 10 9)
           // (16 19 18 17)
    top
        type patch;
        faces
            (3 7 6 2)
            (2 6 15 11)
            (11 15 14 10)
            //(19 23 22 18)
    dummy
        type wall;
        faces
            (0 1 5 4)
            (1 8 12 5)
            (8 9 13 12)
            //(16 17 21 20)
    channel
        type wall;
        faces
   	     (16 19 18 17)
   	     (16 20 23 19)
   	     (20 21 22 23)
   	     (17 18 22 21)
 dummy_inlet
        type wall;
        faces
           (19 18 22 23)
 inlet_channel
        type wall;
        faces
            (16 17 21 20)
mergePatchPairs
(dummy dummy_inlet)
davcrisp is offline   Reply With Quote
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 14:41
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Problems with stl from dem and background mesh VLima OpenFOAM Meshing & Mesh Conversion 1 May 4, 2020 12:04
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
