[snappyHexMesh] simpleGrading (1 1 8) in blockMesh causes problem with nCellsBetweenLevels |
September 25, 2022, 15:06 |
Giles Richardson
Anyone notice that using simpleGrading factors = (1 1 8) in blockMesh causes
a problem with the nCellsBetweenLevels setting in snappyHexMesh? In other words if you have simplegrading factor = 8, it appears to disable the nCellsBetweenLevels functionality. |
blockmesh, ncellsbetweenlevels, simplegrading, snappyhexmesh |
[OpenFOAM] Error !! No. of points and fields don't match | mkjmalik | ParaView | 4 | November 2, 2019 10:37 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
[blockMesh] meshing a cylinder | Nico A. | OpenFOAM Meshing & Mesh Conversion | 6 | June 19, 2017 14:12 |
pimpleDyMFoam - rho not found | maasyraf3 | OpenFOAM Running, Solving & CFD | 10 | June 5, 2017 13:05 |
blockMesh problem | shahilc | OpenFOAM Pre-Processing | 3 | March 4, 2016 13:51 |
