[mesh manipulation] Problem with refineMesh & neighbor matching
Old   October 3, 2022, 09:53
Default Problem with refineMesh & neighbor matching
Michael S.
Wowbagger is on a distinguished road
Send a message via Skype™ to Wowbagger
Dear Foamers,
I am trying to run a 3D case which I started from a 2D case in different settings.
2D case was running well.
Now I tried to do in 3D with an inclined Mesh and using refineMesh in a similar way as I saw it in the DTCHull tutorials.
I got two problems so far.
First problem is a warning.
I tried to refine two times. First time refinement is ok.
But second time there are a lot of warnings like this:
--> FOAM Warning :
From function void Foam::cellCuts::setFromCellCutter(const Foam::cellLooper&, const Foam::List<Foam::refineCell>&)
in file meshCut/cellCuts/cellCuts.C at line 2393
Found loop on cell 216103 that resulted in an unexpected bad cut.
Suggestions:
- Turn on the debug switch for 'cellCuts' to get geometry files that identify this cell.
- Also keep in mind to check the defined reference directions, as these are most likely the origin of the problem.
I suggest this is not really a problem, as paraFoam is showing what I want.
But I want to know how to do it really right. I did the debugging with cellCut and tried every change in reference direction which makes sense for me.
But I wasn't able to get rid of this warning. And I am not sure at all if this is related to the second Problem.
Second Problem is a neighbour matching error.
Trying to run simpleFoam after is showing:
face 1 area does not match neighbour by 0.00812436% -- possible face ordering problem.
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
Displaying the faces in paraFoam shows the correct faces. Where can i change the called 'matchTolerance' to do this automated? I thought this would be the decomposeParDict but it isn't.
Can anyone help me?
I attached the case if anybody want to replicate this.
As I am trying to get better in OpenFoam every hint to a mistake is welcome.
Best regards
Michael
File Type: png Bildschirmfoto vom 2022-10-03 14-41-46.png (15.9 KB, 7 views)
Wowbagger is offline   Reply With Quote
Old   October 10, 2022, 13:22
Michael S.
No one here who has a guess or a tip?
Best regards
Michael
[mesh manipulation] refineMesh problem with erroneous grid quarkz OpenFOAM Meshing & Mesh Conversion 0 July 9, 2019 06:06
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 20:41
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
