[snappyHexMesh] Getting the Mesh of both sides of a surface
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By Sebastian_Vienna
Old   December 11, 2022, 14:01
Default Getting the Mesh of both sides of a surface
Sebastian Skrna
Sebastian_Vienna is on a distinguished road
Hi everyone
I have a scan of a laserstructured surface (not flat) as an .stl file and my goal
is to get the "imprints" (meshes) of both sides of this surface and the meshes should merge perfectly without a gap.
With snappyHexMesh I can get the mesh of only one side of the surface.
(Attachment: Mesh_of_only_one_side.JPG)
(Attachment: Surface_and_upperSide.JPG)
When i apply snappyHexMesh for each side of the surface in a seperate case and try to merge the meshes of both sides of the surface there is a small gap inbetween.
(Attachment: Upper_and_lower_Side_with_Gap.JPG)
How can i get a perfectly fitting mesh without a gap?
I am very grateful for every idea that could solve this problem.
Best wishes
Sebastian
Sebastian_Vienna is offline   Reply With Quote
Old   December 12, 2022, 03:26
Yann
Yann will become famous soon enough
Hello Sebastian,
What OpenFOAM version are you using? There are 2 ways to achieve it depending on the branch.
Regards,
Yann
Yann is offline   Reply With Quote
Old   December 12, 2022, 03:31
Sebastian Skrna
Hello Yann,
thank you for your reply!
I am using Version 6.
Regards,
Sebastian
Old   December 12, 2022, 03:58
Yann
Thanks for your answer.
In snappyHexMeshDict, you can define cellZones for each side in order to keep both sides in the final mesh, with a snapped interface in-between:
refinementSurfaces
	upperSide
		// Surface-wise min and max refinement level
		level (1 1);
		faceZone upperSide;
		cellZone upperSide;
		cellZoneInside inside;
	lowerSide
		level (1 1);
		faceZone lowerSide;
		cellZone lowerSide;
Have a look at the snappyMultiRegionHeater tutorial.
Regards,
Yann
AtoHM likes this.
Old   December 12, 2022, 07:05
Sebastian Skrna
Hello Yann,
thank you for your fast reply and the hints!
I will try that
Again thank you very much.
Regards,
Sebastian
Yann likes this.
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 10:11
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
