Prolem with surfaceFeatureExtract
1 Attachment(s)
Hell guys,
I want to use snappyMesh to generate meshs from a .stl file. However, I got an error after I run surfaceFeatureExtract. I had changed name of stl file and surfaceFeatureExtractDict, but it didn't work. And my foam version is OF-v2112. The format of .stl file is ASCII. Error message: Code:
Create time Code:
constant Code:
clyn.stl Wish for your help, Zhong. |
It seems that I write a 'clyn' but not a 'cyln' in surfaceFeatureExtractDict. I checked many times and didn't find it.
Hi, i looked into your case and the snippet of the stl doesn't start with the usual "solid" entry that an stl file has. Maybe this produces the error?
