Vinzmann |
May 19, 2023 11:06 |
Bad mesh in small channel
1 Attachment(s)
Hello everybody,
I have a small channel in my geometry which is a kind of nozzle. My problem is that my mesh in this channel always looks horrible.
I'd be very thankful if you could take a look at my snappyHexMeshDict and my meshQualityDict.
The small geometry is called duese and the inlet sits at the face of this channel.
| \\ / O peration | Version: 8 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 8;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
keepPatches yes;
geometry
rohr.stl
type triSurfaceMesh;
name rohr;
inGroups (walls);
inlet.stl
name inlet;
cOut.stl
name cOutlet;
inGroups (outlets);
wOut.stl
name wOutlet;
inGroups (outlets);
drossel.stl
name drossel;
inGroups (walls);
duese.stl
name duese;
inGroups (dueseGroup);
kammer.stl
name kammer;
inGroups (walls);
globalRefinement
type searchableCylinder;
point1 (0 0 0.1);
point2 (0 0 0.2);
radius 0.02;
castellatedMeshControls
maxLocalCells 10000000;
maxGlobalCells 200000000;
minRefinementCells 5;
nCellsBetweenLevels 5;
features
file "rohr.eMesh";
level 4;
file "drossel.eMesh";
level 1;
file "duese.eMesh";
level 3;
file "inlet.eMesh";
level 3;
file "wOut.eMesh";
level 1;
file "cOut.eMesh";
level 1;
file "kammer.eMesh";
level 1;
refinementSurfaces
"(rohr)"
level (3 3);
patchInfo
type wall;
inGroups (walls);
"(kammer)"
level (1 3);
patchInfo
type wall;
inGroups (walls);
"(drossel)"
level (1 1);
gapLevelIncrement 2;
patchInfo
type wall;
inGroups (walls);
"(duese)"
level (5 5);
patchInfo
type wall;
"(inlet)"
level (5 5);
patchInfo
type mappedPatch;
offset (0 0.1 0);
sampleRegion region0;
sampleMode nearestCell;
samplePatch none;
"(cOutlet)"
level (1 1);
patchInfo
type patch;
inGroups (outlets);
"(wOutlet)"
level (1 1);
patchInfo
type patch;
inGroups (outlets);
resolveFeatureAngle 30;
refinementRegions
globalRefinement
mode inside;
levels ((1e15 1));
gapMode mixed;
gapLevel (4 0 4);
rohr
mode distance;
levels ((0.001 2));
inlet
mode distance;
levels ((0.002 2));
kammer
mode distance;
levels ((0.001 2));
drossel
mode distance;
levels ((0.0004 4) (0.0008 3));
locationInMesh (0.001 0.001 0.1);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 1;
nSmoothInternal 1;
tolerance 0.7;
nSolveIter 100;
nRelaxIter 8;
nFeatureSnapIter 80;
implicitFeatureSnap false;
explicitFeatureSnap true;
multiRegionFeatureSnap false;
addLayersControls
relativeSizes true;
layers
walls
nSurfaceLayers 7;
duese
nSurfaceLayers 10;
inlet
nSurfaceLayers 6;
thickness 2;
expansionRatio 1;
expansionRatio 1.2;
//finalLayerThickness 2;
thickness 2;
minThickness 0.0001;
nGrow 0;
featureAngle 230;
slipFeatureAngle 90;
nRelaxIter 1;
nSmoothSurfaceNormals 2;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.3;
maxThicknessToMedialRatio 0.3;
minMedialAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 1;
additionalReporting true;
meshQualityControls
#include "meshQualityDict"
relaxed
maxNonOrtho 35;
maxNonOrtho 35;
nSmoothScale 8;
errorReduction 1.5;
writeFlags
scalarLevels
layerSets
layerFields
mergeTolerance 1e-6;
My meshQualityDict looks like this:
FoamFile
version 2.0;
format ascii;
class dictionary;
object meshQualityDict;
minFaceWeight 0.02;
maxBoundarySkewness 3;//20
maxInternalSkewness 2;//4
maxConcave 30;//40
minVol 1e-13;
minTetQuality 1e-3;//1e-15
minArea -1;
minTwist 0.02;
minDeterminant 0.01;//0.001
minFaceWeight 0.05;//0.05
minFaceFlatness -1;
minVolRatio 0.01;//0.01
minTriangleTwist -1;
nSmoothScale 8;//8
errorReduction 1.5;//.75
I've attached a picture of the mesh.
Best regards,
Vinz
