[Gmsh] gmshToFoam Recombined Wedge -> defaultFaces |
Carl Kohrs
Rep Power: 7 ![]() |
I'm generating an axisymmetric mesh in GMSH with a rotated and extruded mesh about the y-axis and then using gmshToFoam. I assign the physical Surfaces (inlet,outlet, front, back, etc.) in GMSH and run my simulation successfully as long I do not recombine the surfaces that touch the y-axis. However, if I recombine these surface, some of the triangles at the wedges become part of "defaultFaces" which interrupts my workflow (these should form the internal cell faces and are not located on the surface). I need to run many cases like this of varying geometries, so I need a reliable solution to this rather than a once-off.
I'm sure there are workarounds to remove the faces but I'd rather solve this from the beginning to avoid possible future problems. To be clear, the issue does not show up in GMSH in the .geo or the .msh files, but only after gmshToFoam step. |
Rep Power: 0 ![]() |
I hope this message finds you well. I am currently experiencing the same issue and would greatly appreciate any guidance or solutions you might be able to provide. Thank you in advance for your assistance. |
Display Modes | |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 7 | September 18, 2024 05:52 |
chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall | JayDeeUU | OpenFOAM Pre-Processing | 16 | July 22, 2021 21:17 |
gmshToFoam export creates defaultFaces | deepbandivadekar | OpenFOAM Pre-Processing | 0 | June 27, 2018 11:53 |
rhoPimpleFoam hardship | petrus | OpenFOAM Running, Solving & CFD | 0 | October 7, 2016 02:41 |
Axisymmetric Whirl BCs; Wedge or Cyclic? | c_dowd | OpenFOAM Pre-Processing | 4 | December 5, 2012 10:38 |
