[snappyHexMesh] Modelling Rotor: To use MergeMeshes or not?
Like Tree1Likes
  • 1 Post By AtoHM
Old   September 21, 2023, 06:45
Default Modelling Rotor: To use MergeMeshes or not?
Niall O'Neill
nialloneill is on a distinguished road
Hello, I am modelling a wind turbine rotor and am trying to figure out the best way to do it.
For now I am using snappyHexMesh and am having significant difficulties getting a good snap quality. I have seen some examples where people create a mesh of the rotating region and a mesh of the non rotating region, and then merge the meshes after. Is this a good practice?
Thanks
nialloneill is offline   Reply With Quote
Old   September 25, 2023, 04:48
Alczem is on a distinguished road
Hey
It is what I usually do when I am not satisfied with snappyHexMesh. Make sure that the coupled patches match pretty well, and don't forget to change the boundary file to create the ACMIs once the meshes are merged together.
Alczem is offline   Reply With Quote
Old   September 25, 2023, 08:00
M
AtoHM is on a distinguished road
my 2 cents:
When not using overset mesh, having stationary and rotating parts in the same model usually requires using different meshes and coupling through interfaces. So, what Alczem already states, plus I'd like to point out, that ACMI interfaces are not mass-conservative. openfoam.org has introduced a new interface algorithm called NCC which is mass-conservative and replaced ACMI in the recent releases: https://cfd.direct/openfoam/free-sof...rmal-coupling/
Alczem likes this.
AtoHM is offline   Reply With Quote
How much does the source code for this turbulent flow CFD code worth in US $? Dr Youssef Hafez Main CFD Forum 43 January 4, 2023 02:13
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Low-Re Modelling doerschlott OpenFOAM Running, Solving & CFD 4 June 23, 2022 07:53
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM hjasak OpenFOAM Announcements from Other Sources 2 February 13, 2017 05:59
