Adding layers distorts internal mesh
2 Attachment(s)
I am finding that if I add a thick layer on one of the domain boundaries, SHM makes a real mess of the mesh at the other surfaces, as it shrinks the internal mesh to make way for the layer. In the example below, the mesh at the top of the cube is stretched horribly. Is there any way to control this better (other than to use a thinner layer)? I couldn't see anything in the snappyHexMeshDict controls ... any suggestions would be welcomed.
/*--------------------------------*- C++ -*----------------------------------*\ |
oO, it appears you are running the Foundation version, right?
I use the ESI version for meshing and cannot remember seeing it shift this way at another boundary so far away and parallel to it. Any chance you can try the same with ESI OpenFOAM? There is also an additional mesh shrinker available there, which behaves differently from the default one (that is probably used here and somewhat similar to the ESI default). You could also provide us the stl and I can check for myself in the evening. |
Great suggestion - I will try it out this afternoon and let you know how I get on. Many thanks.
I don't see why it would make a difference, but you may try to explicitly define 0 layers on your cube top surface to see if it affects the mesh.
Long time ago I had a really confusing issue on a mesh and it was related to specifying 0 layers on a surface or leaving it undefined, in a place where it wasn't supposed to make a difference. So I guess it would be worth trying, just to make sure. |
Cheers Yann - I'll give that a go this afternoon as well. Stand by!
Thats the super expert knowledge here :) I am curious if it helps. It if does not make a difference, you can try to prescribe 1 layer on the top with a region-specific firstLayerThickness of your "normal cell size" (you can prescribe these parameters globally like you did, or for each region separately by adding them again inside the specific region{ ... } part). Code:
layers { |
2 Attachment(s)
Wow - I tried Yann's suggestion first, since it was the easiest/quickest to try:
layers { I'll try the ESI version later on this afternoon, just to complete the story. But in the meantime - many thanks to you both for your suggestions. |
1 Attachment(s)
Now what is going on... As I understand it : specifying 0 layers ensure the patch will not be affected by the layer addition. It's a way to freeze the patch. Not specifying anything means the patch might be affected by the layer addition, even if there is no layer to be inserted on this patch. The best example for that would be the side walls of your cube. You didn't specify anything for those patches in the layers section, but they are affected by the layer addition on Zneg (see screenshot) If you specify 0 layers on those walls, it will be frozen and the layers will get killed close to the wall. Now concerning your cube top face it is pretty hard to now why you get this result. I can only guess it might be a side effect of the mesh morphing on the side walls and surrounding mesh. So whether your should define a number of layers or not depends on what behavior to want on the patch. |
4 Attachment(s)
That's brilliant. I tested it with another case, for a cylinder on a surface ("ground"):
- if I do not specify anything for the sides and top of the cylinder, the mesh shrinkage really mangles the interior mesh, corrupting the snapping to the cylinder (see pics 1 & 2); - if I explicitly specify 0 layers on the sides and top of the cylinder I get some degenerate cells at the bottom of the cylinder, at the point where the cylinder meets the ground (see pic 3) - and if I explicitly specify 0 layers on the top alone I get a perfect mesh (see pic 4) |
Just a quick update on this one - I tried snappyHexMesh under v2112, and got exactly the same behaviour with the same setup ... there are clearly more options in the v2112, but I stuck with the default shrinkage model and just read the notes in the annotated SHM dictionary, and this prompted me to try adding the following to the addLayersControls section:
nMedialAxisIter 10; |
Interesting. I never touched this and wouldn't have either in this situation. Also I am finding the doc weird one this, its a num of iteration kind of parameter but seems to spatially limit the zone of influence of the distortion. How do I know the extent of this region by the number of iterations? Ominous!
Thanks for your feedback Tobermory, I would not have thought to use this parameter for this specific issue.
Now I wonder what kind of influence it can have on other cases. |
