error with addLayers
Hello all,
I created a Mesh with snappyHexMesh using castellatedMesh and Snap. Now I want to add a layer around my patch. I keep getting the same error and I can't understand it. If someone could help me out that would be appreciated. the forum says it doesn't accept my log and snappyHexMeshDict so I've pasted part of it below. Thank you |
error:
Checking mesh with layer ... Code:
addLayersControls |
Unfortunately no helpful error and your sHMD appears fine to me. Can you look for a tutorial case with layer generation and verify it works there? What OF version are you using?
Thank you all for your answer,
I figured it out when I use a higher layer thickness. I didn't think about using relaxed value for the mesh quality. |
