[snappyHexMesh] generating cylinder sharpedges for snappyHexMesh without stl
Old   January 28, 2025, 03:25
Default generating cylinder sharpedges for snappyHexMesh without stl
AlxB is on a distinguished road
the standard process to snap and mesh correctly the sharp edges of a cylinder with snappyHexMesh looks like:
.use surfaceFeatureExtract on the cylinder stl file to generate the emesh file
.specify the emesh file on the castellation feature section of the snappyHexMesh dict
Well,
would it be another way to do it such as:
.using a searchableCylinder in snappyHexMesh and getting its edges
.and thus not using surfaceFeatureExtract and stl file anymore ?
Thank you
AlxB is offline   Reply With Quote
edges, mesh, searchablecylinder, snappyhexmesh
How to implement time-varying boundary conditions in an enclosed cylinder Alejandro-FA OpenFOAM Pre-Processing 0 May 14, 2020 07:29
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[blockMesh] BlockMesh with cylinder and halfsphere ich558 OpenFOAM Meshing & Mesh Conversion 0 April 11, 2019 06:17
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
