[Sponsors] | |||||
[blockMesh] very bad quality of cylinder mesh using blockMesh |
Rep Power: 6 ![]() |
hello,
I try with blockMesh to properly mesh a cylinder, hollowed out at its centre. Despite a very good looking, the check mesh is very bad. What could explain this ? Thanks here below are thecheckMesh log, the blockMesh log and the blockMeshDict : Code:
Create time
Create mesh for time = 0
Check mesh...
Enabling user-defined geometry checks.
Time = 0
Mesh stats
faces: 192500
internal faces: 182500
cells: 62500
faces per cell: 6
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 62500
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
inlet 2500 2600 ok (non-closed singly connected)
outlet 2500 2600 ok (non-closed singly connected)
side 2500 2600 ok (non-closed singly connected)
hub 2500 2600 ok (non-closed singly connected)
".*" 10000 10000 ok (closed singly connected)
Checking faceZone topology for multiply connected surfaces...
No faceZones found.
Checking basic cellZone addressing...
No cellZones found.
Checking basic pointZone addressing...
No pointZones found.
Checking geometry...
Overall domain bounding box (-2.220446e-16 -1 -1) (1 1 1)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (5.8963373e-17 7.8558055e-18 3.9279028e-18) OK.
***High aspect ratio cells found, Max aspect ratio: 2.4865046e+147, number of cells 60000
<<Writing 60000 cells with high aspect ratio to set highAspectRatioCells
***Zero or negative face area detected. Minimum area: 0
<<Writing 80952 zero area faces to set zeroAreaFaces
***Zero or negative cell volume detected. Minimum negative volume: -2.5077213e-37, Number of negative volume cells: 59712
<<Writing 59712 zero volume cells to set zeroVolumeCells
Mesh non-orthogonality Max: 90 average: 87.67614
*Number of severely non-orthogonal (> 70 degrees) faces: 192.
***Number of non-orthogonality errors: 174908.
<<Writing 175100 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
***Max skewness = 3.8802559e+117, 4997 highly skew faces detected which may impair the quality of the results
<<Writing 4997 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Checking faces in error :
non-orthogonality > 65 degrees : 175100
faces with face pyramid volume < 1e-13 : 9800
faces with face-decomposition tet quality < 1e-15 : 0
faces with concavity > 80 degrees : 0
faces with skewness > 4 (internal) or 20 (boundary) : 0
faces with interpolation weights (0..1) < 0.02 : 0
faces with volume ratio of neighbour cells < 0.01 : 0
faces with face twist < 0.02 : 0
faces on cells with determinant < 0.001 : 0
<<Writing 184900 faces in error to set meshQualityFaces
Failed 6 mesh checks.
End
Create time
Creating block mesh from "system/blockMeshDict"
Creating block edges
No non-planar block faces defined
Creating topology blocks
Creating topology patches - from boundary section
Creating block mesh topology
Check topology
Basic statistics
Number of internal faces : 4
Number of boundary faces : 16
Number of defined boundary faces : 16
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list (topological search)...
Deleting polyMesh directory "constant/polyMesh"
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale (1 1 1)
Block 0 cell size :
i : 0.031410759 .. 0.031410759
j : 0.02 .. 0.02
k : 1 .. 0
Block 1 cell size :
j : 0.02 .. 0.02
k : 1 .. 0
Block 2 cell size :
j : 0.02 .. 0.02
k : 1 .. 0
Block 3 cell size :
j : 0.02 .. 0.02
k : 1 .. 0
No patch pairs to merge
Writing polyMesh with 0 cellZones
Mesh Information
boundingBox: (-1 -1 0) (1 1 1)
nPoints: 67600
nCells: 62500
nFaces: 192500
nInternalFaces: 182500
Patches
patch 0 (start: 182500 size: 2500) name: inlet
patch 1 (start: 185000 size: 2500) name: outlet
patch 2 (start: 187500 size: 2500) name: side
patch 3 (start: 190000 size: 2500) name: hub
End
| \\ / O peration | Version: v2406 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
scale 1;
// Location and Dimensions of the cylinder:
ROTx0 0;
ROTy0 0;
ROTz0 0;
Hrot 1;
Rrot 0.5;
Rhub 1;
grad 25;
// NOTE: this will produce a washer oriented along the Z axis//
// Calculations for cylinder geometry:
h #eval{$Hrot+$ROTz0};
vx #eval{$ROTx0+$Rrot};
nvx #eval{$ROTx0-$Rrot};
vy #eval{$ROTy0+$Rrot};
nvy #eval{$ROTy0-$Rrot};
// Calculations for hub:
hHB #eval{$Hrot+$ROTz0};
vxHB #eval{$ROTx0+$Rhub};
nvxHB #eval{$ROTx0-$Rhub};
vyHB #eval{$ROTy0+$Rhub};
nvyHB #eval{$ROTy0-$Rhub};
// Calculations for arcs:
c1 #eval{$ROTx0 + ($Rrot*cos(45.0))};//cosine in 1st quadrant
s1 #eval{$ROTy0 + ($Rrot*sin(45.0))};//sine in 1st quadrant
c2 #eval{$ROTx0 + ($Rrot*cos(135.0))};//cosine in 2nd quadrant
s2 #eval{$ROTy0 + ($Rrot*sin(135.0))};//sine in 2nd quadrant
c3 #eval{$ROTx0 + ($Rrot*cos(225.0))};//cosine in 3rd quadrant
s3 #eval{$ROTy0 + ($Rrot*sin(225.0))};//sine in 3rd quadrant
c4 #eval{$ROTx0 + ($Rrot*cos(315.0))};//cosine in 4th quadrant
s4 #eval{$ROTy0 + ($Rrot*sin(315.0))};//sine in 4th quadrant
// Calculations for hub arcs:
c1HB #eval{$ROTx0 + ($Rhub*cos(45.0))};//cosine in 1st quadrant
s1HB #eval{$ROTy0 + ($Rhub*sin(45.0))};//sine in 1st quadrant
c2HB #eval{$ROTx0 + ($Rhub*cos(135.0))};//cosine in 2nd quadrant
s2HB #eval{$ROTy0 + ($Rhub*sin(135.0))};//sine in 2nd quadrant
c3HB #eval{$ROTx0 + ($Rhub*cos(225.0))};//cosine in 3rd quadrant
s3HB #eval{$ROTy0 + ($Rhub*sin(225.0))};//sine in 3rd quadrant
c4HB #eval{$ROTx0 + ($Rhub*cos(315.0))};//cosine in 4th quadrant
s4HB #eval{$ROTy0 + ($Rhub*sin(315.0))};//sine in 4th quadrant
vertices
// Vertices for the cylinder :
// x y z
($vx $ROTy0 $ROTz0) // 0 to 3
($ROTx0 $vy $ROTz0)
($nvx $ROTy0 $ROTz0)
($ROTx0 $nvy $ROTz0)
($vx $ROTy0 $h) // 4 to 7
($ROTx0 $vy $h)
($nvx $ROTy0 $h)
($ROTx0 $nvy $h)
($vxHB $ROTy0 $ROTz0) // 8 to 11
($ROTx0 $vyHB $ROTz0)
($nvxHB $ROTy0 $ROTz0)
($ROTx0 $nvyHB $ROTz0)
($vxHB $ROTy0 $h) // 12 to 15
($ROTx0 $vyHB $h)
($nvxHB $ROTy0 $h)
($ROTx0 $nvyHB $h)
// block: 8 vertices with local coordinate system is right-handed
blocks
hex ( 0 3 11 8 4 7 15 12) ( $grad $grad $grad ) simpleGrading (1 1 0)
hex ( 3 2 10 11 7 6 14 15) ( $grad $grad $grad ) simpleGrading (1 1 0)
hex ( 2 1 9 10 6 5 13 14) ( $grad $grad $grad ) simpleGrading (1 1 0)
hex ( 1 0 8 9 5 4 12 13) ( $grad $grad $grad ) simpleGrading (1 1 0)
edges
arc 0 1 ($c1 $s1 $ROTz0)
arc 1 2 ($c2 $s2 $ROTz0)
arc 2 3 ($c3 $s3 $ROTz0)
arc 3 0 ($c4 $s4 $ROTz0)
arc 4 5 ($c1 $s1 $h)
arc 5 6 ($c2 $s2 $h)
arc 6 7 ($c3 $s3 $h)
arc 7 4 ($c4 $s4 $h)
arc 8 9 ($c1HB $s1HB $ROTz0)
arc 9 10 ($c2HB $s2HB $ROTz0)
arc 10 11 ($c3HB $s3HB $ROTz0)
arc 11 8 ($c4HB $s4HB $ROTz0)
arc 12 13 ($c1HB $s1HB $h)
arc 13 14 ($c2HB $s2HB $h)
arc 14 15 ($c3HB $s3HB $h)
arc 15 12 ($c4HB $s4HB $h)
// boundary: looking from inside the block in a clockwise direction
boundary
inlet
type patch;
faces
(0 1 9 8)
(1 2 10 9)
(2 3 11 10)
(3 0 8 11)
outlet
type patch;
faces
(4 12 13 5)
(5 13 14 6)
(6 14 15 7)
(7 15 12 4)
side
type patch;
faces
(0 4 5 1)
(1 5 6 2)
(2 6 7 3)
(3 7 4 0)
hub
type patch;
faces
(8 12 13 9)
(9 13 14 10)
(10 14 15 11)
(11 15 12 8)
mergePatchPairs
Hey!
There is probably something wrong in the order of the vertices or the blocks, but I cannot tell for sure, I only use blockMesh on very rare occasions. What I can suggest is to simplify your blockMeshDict by meshing only a quarter of your geometry (so only one block) and then use mirrorMesh to duplicate this quarter into a half and a second time to duplicate it into your full geometry. That should help in pinpointing the error. |
| Tags |
| blockmesh, checkmesh, cylinder, quality |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [Ansys Meshing - Fluent] Want to know the influence of mesh quality | y__tb | FLUENT | 2 | May 12, 2022 22:36 |
| [snappyHexMesh] SHM Bad quality snapping/terracing | ryan55510 | OpenFOAM Meshing & Mesh Conversion | 0 | April 20, 2022 21:20 |
| decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
| [snappyHexMesh] Bad quality mesh at external corners | Bollonga | OpenFOAM Meshing & Mesh Conversion | 2 | October 31, 2017 14:42 |
| [ICEM] Bad Quality | **Anny** | ANSYS Meshing & Geometry | 7 | May 28, 2015 06:03 |
